Cisco Jabber - problem with certificates
ziqex
Level 4
Level 4
Hello everyone,
I face the following problem after starting the Cisco Jabber app. The following message is displayed.
"Certificate used for enryption bt the IDP is no longer valid. Please verify the certificate used by the IDP. You must update the IDP metadata on the Cisco Unified Communications Manager after regenerating the IDP servers certificate."
I tried bypassing the message but it is always present.
I used the bug search tool but did not find anything related to IDP.
Please advise. Thank you.
Jaime Valencia
That's related to your SSO, review your configuration and the SSO logs.
java
if this helps, please rate
Jaime Valencia
java
