CMS-API 3.0 /calls/<call id>/participants/* with filterIds=<participant id> and mode=exclude
Thomas GER
i tried to use the endpoint
to mute audio for all participants, excluding one specific ID:
rxAudioMute=true
mode=exclude
But that does always change ALL participants.
The "filterIds" attribute is always ignored.
(Also tested with the Postman-Samples and double checked the CMS-API logs -> My API-Reqests are apparently correct.)
What did I miss? Thank you in advance!
Thomas GER
The solution is:
We must send "filterIds" and "mode"  as a QueryParams, not in the Request-Body!
(I think the API-Documentation could be improved:
https://ciscocms.docs.apiary.io/#reference/call-related-methods/call-methods/set-properties-for-all-participants-in-a-conference)
Thomas GER
The solution is:
