I successfully tested CMS webapp interop with to s4b using CMS (2.2) on a regular PC, but i now need to use it from a kiosk webapp (win10, chromium framework with no tab/plugin support) that needs to call out an s4b user/account.
My biggest issue is that i can't embed the cms webapp into an iframe resulting in loosing my entire context when i open the cms webapp (in fact my kiosk webapp is killed and replaced at that point).
If i can't embed it, can i use other webrtc apps/sdk that interop with CMS? Does the jabber guest sdk interop (i don't have user accounts/logins on the kiosk side) so that i can easily embed it in my own app to setup a video call to an s4b user?
