Configuring Webex Connect integration with Outlook
bimckenz
I can't find a document on how to integrate Webex Connect with Outlook for presence and calendaring. Can someone please point me to document that describes how to integrate?
Thank You
mvild
There is nothing to do to 'integrate' Connect with Outlook from an admin perspective as the Connect client will use the standard MS APIs for presence, IM, calendaring.  The user need only check the boxes in preferences which should already be done as default.  Refer to the Setting up your connection to Microsoft Outlook from the online Connect User Guide.  http://support.webex.com/webexconnect/70/user/en_US/help/index.htm#20689.htm
