CWMS 2.5 Installation Stuck
hypermatt
i deploy the cwms 2.5 ova  without IRP , 50 users ,
use vcenter 5.1 to deploy the cwms ova
i sync the ntp from the esxi host and confirm the dns server can resolve the hosts
But i can't continue the system configuration to setup my mail server & time zone
because my site url & admin-site url can't work ,
dpetrovi
Per screen shots provided I see few things:
1. You are using 'webex' as a hostname for your Admin URL. This might work now, but per documentation, it is required not to use it: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_5/Planning_Guide/Planning_Guide/Planning_Guide_chapter_0100.html#concept_2E31146FD0DA462A8FB70A9E54534677
2. Your CPU is not matching the requirements so your System Check is failing and if continue with the deployment your system won't be supported by TAC.
You need to pass System Check to successfully setup your system. You need to ensure all the network and DNS requirements are fulfilled before you setup your system. Please consult this document for all the needed information: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_5/Planning_Guide/Planning_Guide/Planning_Guide_chapter_0100.html#concept_DDD6AF3E341B4C6A9C5C65229143F305
I hope this will be of help. Do let us know if you have any additional questions.
Kind regards,
-Dejan
Dear Sir
i try to use any other hostname ,
like web1 (admin site), web2(private url), web3(public url)
but still got the same situation ... can't finish installation ,
My server is cisco ucs220 m3 with intel xeon 2620 @ 2.00GHz  x2
i try to deploy the cwms 2.5 to my dell poweredge 2950  @2.83GHz x2 but get the same situation
is cwms 2.5 support third party server or only can deployment on cisco server  ?
thx for your reploy
Cisco WebEx Meetings Server supports only Cisco UCS server as the hardware platform for Virtual Machines.Here is the list of hardware supported based on the system size: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_5/Planning_Guide/Planning_Guide/Planning_Guide_chapter_00.html#reference_EE2655849348437FB3A34F4C4D3E1F71
Additionally, make sure SMTP server is reachable during deployment and that Admin and WebEx Site URLs are resolvable in the DNS used.
Kind regards,
-Dejan
