04-05-2017 09:52 AM - edited 03-17-2019 06:47 PM
I am experiencing voice quality issue with Cisco Jabber 11.5.1 running Windows 10 in some locations I travel to, most likely due to slower WiFi speed. How do I turn on the low bandwidth mode?
Solved! Go to Solution.
04-07-2017 09:20 AM
Not on Windows, it's for Android, iPhone or iPad only.
04-05-2017 11:10 AM
I'm assuming you're referring to what CIPC had?
04-07-2017 06:48 AM
Yes. I've clicked around the Jabber Windows Client menu and can't figure out where to go to turn this feature on. I search the user guide but did not find any reference. The planning guide does refer to it. http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_5/CJAB_BK_C6FFF6D8_00_cisco-jabber-115-planning-guide/CJAB_BK_C6FFF6D8_00_cisco-jabber-115-planning-guide_chapter_010.html
So I am puzzled.
04-07-2017 08:26 AM
But it's not applicable to you, because you're asking J4W
If users have issues with voice quality when using Cisco Jabber for Android or Cisco Jabber for iPhone and iPad, they can turn low-bandwidth mode on and off in the client settings.
04-07-2017 09:05 AM
So just to confirm, this option is not available for Jabber 11.5 running on Windows 10 on a laptop?
04-07-2017 09:20 AM
