I need to understand how the TFTP works
xtgb
 Hi guys,
I need to understand how the TFTP works. I used the following command to install Jabber:
msiexec.exe /i CiscoJabberSetup.msi /quiet CLEAR=1 PRODUCT_MODE=Phone_Mode AUTHENTICATOR=CUCM TFTP=1.2.3.4
And everything worked fine, but I tried to unistall and reinstall Jabber using a wrong TFTP wrong on purpose and still I was able to loggin on Jabber so... how it's works Jabber? My thought was that Jabber download the config file each time an user launch the softphone but since I can login with a wrong TFTP server address... Means that the config file is downloaded the first time I launched Jabber, maybe on my local user folder, and the following times I launch Jabber get the file from there? Where can I find the config file? A user who has never launch Jabber, if my thought is correct, should have problems to download the file with the wrong TFTP right?
Another question, how can I set up  secondary TFTP? Just adding another TFTP like this?
msiexec.exe /i CiscoJabberSetup.msi /quiet CLEAR=1 PRODUCT_MODE=Phone_Mode AUTHENTICATOR=CUCM TFTP=1.2.3.4 TFTP=4.3.2.1
Many thanks
Hello.
Have you tried with another ftpt software? There are many other options you can test.
And if you want a second server, I think you need a second network interface with a valid IP configured so the server can hear in that interface.
Hi Jose,
Thanks for your reply. We're not using any ftp client and regarding the secondary tftp, I only need to know how to set it up during Jabber installation, the network thing is already done.
