Jabber 11.9 fast busy when using Expressway
Eduardo Cruz
I'm getting intermitent errors (487-Response) for calls to Jabber 11.9 crossing Expressway. When Jabber are inside the network, everything is fine.
These errors are intermitents. For the inside user, it gets "Call Failed, try again" and for Jabber Client "You have missed a call from ..."Attached two Expressway-C event logs, one working fine and other with problem.
What's common cause for "487-Responses" when using Expressway?
Thank you
0 Replies 0
