Jabber 12 Multi-line Ring tones
pfcu12800
Is it possible to setup multi-lines in jabber to each have their own ringtone?
Thanks in advance!
Jaime Valencia
No, that doesn't seem to be possible, you only get the single option under notifications, you can get in touch with your SE/AM to submit a PER for this.
java
if this helps, please rate
Jaime Valencia
java
