Supported Servers for On-Premises Deployments
- Cisco Unified Communications Manager versions 7.1.4 to 9.0
 Note | Cisco Jabber for Windows supports Cisco Unified Communications Manager 7.1.3 if you install the following COP file to enable CSF devices: ciscocm.installcsfdevicetype.cop.sgn.Download ciscocm.installcsfdevicetype.cop.sgn from the Cisco Jabber for Windows administration package on Cisco.com.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
