Jabber call control licensing question
Matt Reeve
So if i have a client with BE6K and Enhanced licening with Jabber Desktop client and a physical 8861 handset can i click on the "use my phone for calls" option and select my Cisco 8961 handset ? or would i need to use Enhanced plus? i am unsure as the Jabber client isnt acting as a full voice client as such so i want to ensure i have the correct answer.
I ideally would like a document link to back up the answer as evidence.
Donald Jones
Yes you can. You would only need Enhanced Plus license if you wanted to add softphone capability to Jabber, extend Jabber voice and video to a mobile device or have a second deskphone.
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_1/JABW_BK_E4CC9599_00_environment-configuration-guide_chapter_010.html#JABW_TK_C6049548_00
Don
HI All,
Platform
Cisco Unified CM Administration
System version: 9.1.2.10000-28
Cisco Unified CM IM and Presence
System version: 9.1.1.31900-1
JABBER: 9.2.6 build 12639
Windows Client 7/8
Question
With No. 1 of user profiles + No 1 Connect Licensing Enhanced (9.X) (NO PLUS) can do you configure two devices voice (6941 handset + deskstop Jabber client) and by "end user GUI" select which one to keep active?
Only one device support at the same time for voice capability: 6941 handset or deskstop Jabber client.
Many thanks
