Jabber for Mac not showing phone numbers
Jon Van Deurzen
I have Jabber for Mac 10.5.1 and it does not show any phone numbers for users. I am synced to Active Directory. CUPS version 8.5.2.10000-49.
I have tried to change the LDAP Attributes so that: BusinessPhoneNumber, BusinessMobilePhone, & PrimaryPhoneNumber are all set to "ipPhone". And I still get nothing in Jabber. It works just fine with Personal Communicator for older versions on Windows and such. But no luck with Jabber for Mac.
Any thoughts? Any possible solutions?
Jaime Valencia
Have you properly configured the jabber-config.xml file for that???
There's a directory integration chapter in the config guide with all the details.
java
if this helps, please rate
