Jabber for mobile mobile icon
Joe Bohelski
Is there a way to disable the ability to deselect the "Show icon when mobile" option in Jabber for Mobile?  Having some issue with people setting this to appear to be using J4W, when they're actually not (meaning they're lying about where they are).  If people are using Jabber on their mobile device we want to make sure the status is showing accurately, not what they want it to show.
Thanks in advance.
Jaime Valencia
AFAIK there is no way to remove that switch from the client
java
if this helps, please rate
Jaime Valencia
java
Dang. Thanks, Jaime.
