Jabber: Tweak SIP Timers for loose Networks
Hey Folk..
This is Juan,
Hey I have an issue with a client that is from connected form VPN, when he receives a call, somethings the call disconnects. I have taken look at the Wireshar and CUCM Logs.
CUCM says: "Device not Registered" and then sends a "BYE" followed to un-registration Signal.
 In Wireshark, there are REGISTER packets from Jabber to CUCM and CUCM needs to acknowledge with a 200 OK. those packets are send every 115 Secs.
When CUCM detects "Device Unregistered" it is because Wireshark has already lost a couple of those timers. (I am assuming they are connected).
Wanted to ask you these question.
* Which parameters in the SIP Profile should I change in order for the device to Keep registrated for a longer time (or even not to be restrictive at looking SIP: Registar).
I have tried to use the "SIP profile for mobility" That does not work, Jabber do not connects to CUCM, so I had to use the "Default SIP Profile".
Thank you very much for you help.
Juan
0 Replies 0
