Hi Team
We have implemented a collaboration edge deployment before a 6 months a ago
Everything was ok except the last months
Expressway E and C stuck a lot of times and the MRA and also the B2B calls were not working anymore..
With reboot both of them then everything started to work ok
Today we had the same issue.we couldn't login to jabber via MRA.We reboot it both EXP C&E then everything started again to work properly except one thing
The voice is not working any more.Jabber registered to CUCM but we dont have RTP. The same occur if i do outgoing or incoming call to jabber
Attached are the traces from EXP C&E
Do you have any idea?
Version of Exp: 8.1.1
Version of CUCM: 9.1.2
/cc
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
