NTP issue in Edge
V.Naveen Kumar
We have installed Expressway E & C, We have configured two NTP server in both servers.
Issue: In Expressway E,one of the NTP server which is public IP address is in rejected state and local NTP address is in sys-peer node.
In Expressway C, Both Public and Local NTP server are good state
Our Manager requested to remove the Public NTP server
whether we can remove Public NTP server directly in both servers, will it make impact anything ??
Thanks in advance
Jaime Valencia
Not really, you'll only reset the NTP service, either way, if you C and E are not properly synced, you'll get errors as they require to be synced for they to work properly.
java
if this helps, please rate
Thanks Jaime.  I have removed NTP IP address and didn't faced any issue
