Routing calls through HQ voice gateway in case Branch router failure
shinas
We have HQ and one branch, CUCM is located in HQ,  branch is having separate voice gateway and phones in branch are registered to HQ CUCM.
I would like to know if somehow branch voice gateway went down, is there any way to automatically route the PSTN calls through HQ voice gateway. Both gateways in HQ and branch are h323. Please guide how to do this.
Shinas
Jaime Valencia
Yes, adjust your route groups as needed  and perform any digit manipulation if necessary.
java
if this helps, please rate
Jaime Valencia
java
