Spark Issues with Wins10
Ahmed_Azzam
I've been using Spark on Windows 10 PC, after the latest update. Spark is not opening any more and i can not remove and reinstall.
I got a message from Windows installer the attached msg
keglass
Level 7
Level 7
Ahmed,
If you haven't done so already, I recommend you contact Spark technical support for assistance specific to your setup and situation.
https://help.webex.com/docs/DOC-4092#jive_content_id_Cisco_Spark
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
Thanks Kelli... I will do that
Best Regards,
Ahmed Azzam
JamesPrietoJr
Hi I'm having the same issue - I've removed Spark from my Windows 10 laptop several times, and tried to re-install/repair.  The installation seems to go fine, but I get a blank screen (see below) when Spark tries to execute. How do I fix this?
