04-04-2017 03:31 PM - edited 03-17-2019 06:47 PM
I am trying to lab up a phone only mode for jabber clients. I cannot get the android or windows jabber to auto config with SRV using _cisco-uds. I have a cups server but would like this phone only mode to work without one.
Solved! Go to Solution.
04-06-2017 01:20 PM
Review the PRT to find out exactly what is happening
Yes, if you want to use MRA, you need to use SRV records.
04-04-2017 04:11 PM
Do you already have the proper configuration in CUCM for those devices?
04-04-2017 09:39 PM
Yes, I can get them to work when I do advanced settings and point them to CUCM. Cisco Unified Client Services Framework work then and registers.
04-05-2017 08:34 AM
Use nslookup to make sure the PC can actually get the right info, if you get the right info, you'd need to look at a PRT to find out the issue.
Many time the issue is DNS issues.
04-05-2017 10:55 AM
Do I need to upload a jabber config .xml file to CUCM? I am using jabber 11.5.2 on CUCM 10.5.2. Will Cisco _cisco-uds work in "phone" only mode? I am testing on android and Windows-11.5.2 ver.
04-05-2017 11:08 AM
Whether you need a jabber-config.xml or not, is up to you, and your requirements.
Yes, phone mode will work, assuming the user is associated a service profile which does not have IM&P
04-05-2017 02:13 PM
I can only get it to authenticate with CUCM with this config. Since I am using CUCM 10.5 should I use a lower windows jabber version? I am trying to get _cisco-uds and _collab-edge to work on phone only mode. Are there any setup documents for phone only mode and no IMP?
FallbackAuthenticator: CUCM
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
ProductMode: Phone_Mode
TftpServer1: 10.1.1.1
CtiServer1: 10.1.1.1
CcmcipServer1: 10.1.1.1
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
ServiceDiscoveryExcludedServices: CUP,WEBEX
NOT_SPECIFIED
NOT_SPECIFIED
Telephony_Enabled: TRUE
Voicemail_Enabled: TRUE
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
NOT_SPECIFIED
EnableDPIAware: TRUE
04-05-2017 04:12 PM
Phone only mode just means that you will not have an IM&P in your service profile, there should be no need to hardcode anything in the bootstrap for this to work.
I'd suggest you pull a PRT and review the login process to see if you're properly resolving the SRV, and if CUCM can find the user and the associated devices.
04-05-2017 08:11 PM
How do I go about PRT testing? Not great at DNS. Does my CUCM need to be fully DNS integrated?
04-05-2017 10:04 PM
PRT is not a test, it's problem reporting tool. Help -> Report a problem.
If you're using SRV records, you need to have everything properly configured in the DNS so you can resolve to your CUCM server.
04-06-2017 08:45 AM
I can't even get jabber to log in when I set it manually in advanced settings
*CUCM 9 or later
* Use the following server:x.x.x.x
Only way I can get it to work is using bootstrap file. Is there a bug with 11.5.2 Windows jabber?
side note:
Expressway requires use of SRV records correct?
04-06-2017 01:20 PM
