Unity Connection 12.5 LDAP Integration
j.huizinga
Level 6
Level 6
In my LAB I have installed CUCM/IMP/CUC 12.5 (the latest versions)
I Have issues with LDAP integration from CUC with my AD. I can make the configuration (without errors) And when I sync I can see with Wireshark on my AD that the request is made and all is correct. But when I go to "import users" I get:
No AXL Remote or LDAP Servers were found. A Unified Communications Manager and/or LDAP Directory server integration is required to import users.
It is correct that there are no AXL servers, because since version 10.X I don't use that anymore, only LDAP integration (when CUCM is also LDAP integrated)
I had some issue when installing CUC, so maybe I have something weird, but it is also a new version, maybe something else has to be checked?
Has anyone seen this?
Any help would be appreciated
JH
0 Replies 0
