Using a Spark Board to call into a Spark Space?
mem16421
Is it possible for the spark board to call a spark space?  I can call the spark board from a space, but not the other way around.  I can call into a WebEx and it seems to work fine, but then you can't share things like white boards.....
gbekmezi-DD
Level 5
Level 5
If you are in the spark space on your device, you use your device (laptop or phone) to open the space on the spark board.
George
George,
Thank for the reply, but if you are in a conference room with a spark board you want to just join the space and not have to use your laptop to do it.  Just trying to utilize this expensive piece of hardware to its best of its ability.  Thank again
Computer or a phone. If it didn’t integrate with your phone/computer then the board would require a login…another login would seem to me to be an undesirable behavior as well. Having said that, I understand your frustration.
George
