Webex Connect problem SAML2AuthService.do
aman13sharma
Hi Folks,
I am facing a strange problem with webex connect.
While logging to webex connect I get a prompt dispalying message that the following file could not be opened "SAML2AuthService.do"
It prompts me to save it on my system or to search for a program to open it on internet.
Kindly help .. i am unable to login to webex connect due to this.. I have done every possible method from completely uninstallation to webex to upgrading it to latest ver ..but no help..
6 Replies 6
kinglewi
The first thing to try would be going directly to the SSO login from within IE.  I suggest IE,  because that is what connect uses for the SSO login screen that pops up.  You can try going to this url directly to see what happens https://loginp.webexconnect.com/cas/SAML2AuthService.do?org={domain}.  The domain should be the last part of your email address.  If it still fails, see if a co worker has the same problem with the URL.  It would be nice to narrow down the problem to either a network, browser/proxy, or connect issue.  Please let us know what the results are with the above URL.
Thank you
-Kingsley Lewis
This is an issue with the HKCR\MIME\Database\Content Type\text/xml.
Create the following reg keys:
String-> CLSID with value {48123BC4-99D9-11D1-A6B3-00C04FD91555}
Binary-> Encoding with value 08 00 00 00
String-> Extension with value .xml
apoorvbadami
I also have the same issue. it asks me to download SAML2AuthService.xml whereas it should just login. I tried the workaround above but does not work. please advise
the above workaround worked for me.
Thanks Clouse, really appreciated
R
Alex
Hi Clouse,
Worked for me too.
Thank you so much for your help.
BR,
Ricardo
