Webex crashes while selecting recording device
otatop
I'm running windows 10, have a computer mic, a mic on a usb camera, and a Bluetooth headset. If I select the Bluetooth headset mic, and then in the drop down to select a different mic, webex will crash. This happens every time I try that. Additionally, if I attempt to select the Bluetooth headset, it doesn't get any audio.
Also, just now I was on a webex and was using the audio from the usb mic, and it worked for a half hour meeting, then in the next meeting it lasted about 10 minutes but then after that no one could hear me. I had to close webex and reconnect to get the mic working again. I could hear everyone else using the usb speakers with no problem.
keglass
Level 7
Level 7
Keith,
I recommend you contact WebEx Technical Support as they will be able to tell you if the problem you are experiencing has been identified and assist you with a fix ... or help by debugging. They are available 24/7.
Contact WebEx Technical Support | WebEx
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
