webex Sip trunk issue
Eric Fu
hi guys
i have two sip trunks go to webex in CUCM, but it's not working from yesterday , and then i trace calls and find termination caused code is 134217749 and another one is 65 as below picture.
do you have any ideas ??
Dennis Mink
Eric,
assuming the trunk isnt registered, can you set it up without a SIP security profile.
also if it has worked, what was changed when it broke?
also check the expiry date of your certificates both on cucm and on webex
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
Eric,
thanks anyway i reboot CUCM then it was fix
