jolefebv
Hi folks,
I am working on a Webex Teams Bot. It was quite complicated to find all the necessary information to have a running webhook in python. Therefore, I am sharing a simple way to do it here.
It is necessary to have
-Flask: will be used to have your code acting as a small websever.
-Ngrok: Allows you to redirect traffic from a public URL to your machine. Available on https://ngrok.com/  , it's free.
Basically, if you open ngrok, you will have access to an URL on which your machine will be reachable. By using the command ngrok http 5000, I am now listening on localhost:5000. All traffic for http://5a045288.ngrok.io will be redirected to it.
If we retrieve this address in our python code. It shouldn't be a problem to make a webook in a short script.
from __future__ import print_function # Needed if you want to have console output using Flask
import requests
import sys
import json
import os
import time
from flask import Flask, request
token = 'Enter your bot access_token here !' # You can get it on https://developer.webex.com/endpoint-messages-post.html
app = Flask(__name__)
@app.route("/",methods=['POST']) # all request for localhost:5000/ will reach this method
def webhook():
# Get the json data
json = request.json
# Retrieving message ID, person ID, email and room ID from message received
message_id = json["data"]["id"]
user_id = json["data"]["personId"]
email = json["data"]["personEmail"]
room_id = json["data"]["roomId"]
print (message_id, file = sys.stdout)
print(user_id, file=sys.stdout)
print(email, file=sys.stdout)
print(room_id, file=sys.stdout)
if user_id != 'Y2lzY29zcGFyazovL3VzL1BFT1BMRS85M2ViYTZlMi01ZDk2LTRhMmUtYjEyNy1hNzA5YWJjY2NlMDM':
#Loading the message with the message ID
global token #Retrieving token from Global variable
header = {"Authorization": "Bearer %s" % token}
get_rooms_url = "https://api.ciscospark.com/v1/messages/" + message_id
api_response = requests.get(get_rooms_url, headers=header, verify=False)
response_json = api_response.json()
message = response_json["text"]
print(message, file= sys.stdout)
print('******************', file=sys.stdout)
# You can do whatever you want with the message,person_id,room_id over here !
return "Success!"
else:
return "It's my own messages ... ignoring it"
os.popen("pkill ngrok") # clearing previous sessions of ngrok (if any)
os.popen("ngrok http 5000 &") # Opening Ngrok in background
time.sleep(5) #Leaving some time to Ngrok to open
term_output_json = os.popen('curl http://127.0.0.1:4040/api/tunnels').read() # Getting public URL on which NGROK is listening to
tunnel_info = json.loads(term_output_json)
public_url = tunnel_info['tunnels'][0]['public_url']
# Registering Webhook
header = {"Authorization": "Bearer %s" % token, "content-type": "application/json"}
requests.packages.urllib3.disable_warnings() #removing SSL warnings
post_message_url = "https://api.ciscospark.com/v1/webhooks"
# Preparing the payload to register. We are only interested in messages here, but feel free to change it
payload = {
"resource": "messages",
"event": "all",
"targetUrl": public_url,
"name": "MyWonderfulWebHook"
api_response = requests.post(post_message_url, json=payload, headers=header, verify=False) #Registering webhook
if api_response.status_code != 200:
print ('Webhook registration Error !')
exit(0)
if __name__ == '__main__':
app.run(host='localhost', use_reloader=True, debug=True)
Once you have implemented a logic when receiving the message, you can start conversing with your bot
Here is what I can see from the pycharm console:
I hope it helps you making your own bot on webex teams!
Kind regards,
Jonathan
