cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Leonid Baranov on 30-09-2010 10:07:25 AM
A -> B
C - creates monitor call on A -> B
D - creates monitor call on A -> B -- Exception
How can i create two monitor calls and associate them both with one Call?
One monitor call works fine, but if I try to create another one have "Monitor request failed" Exception.
Thanx!
Subject: RE: Create two monitor calls on the same call
Replied by: Mohan Potluri on 01-10-2010 06:20:05 AM
A device can support only one monitoring session. The second monitor session will fail. In your case the options are:
1. If both A and B are observed start the first monior session on A and the second session on B. Both A and B should be phones that support monitoring feature.
2. Instead of a monitor session from B, consult from C to D and complete the conference.
Replied by: Leonid Baranov on 04-10-2010 02:58:47 AM
Thanx for complete answer, I guess it will help.
