cdnadmin
Level 11
Level 11
Subject: RE: New Message from prince christopher joseph in Customer Voice Portal (CV
Replied by: prince christopher joseph on 09-08-2010 07:30:17 AM
The problem is been resolved , I have changed the below parameter
<ssml_validation>strict</ssml_validation> to <ssml_validation>warn</ssml_validation> in the following files of
 ttsrshclient.xml
 ttssapi.xml
of the Nuance vocalizer
This document was generated from CDN thread
Created by: prince christopher joseph on 07-08-2010 05:16:48 AM
Hi All,
I am trying to configure CVP with Nuance Reconizer 9.0 and Vocalizer 5.0.3 , The NSS version is 5.2.2.
I have done configurationas per the CVP cfg guide but still i am getting below error in NSS server
Aug 07 10:35:54.73|TUCPU=0|TKCPU=0|TID=3912|0|9102|LGT=9|SID=EMFMOJLCAAAIJFEEAAAAAAAA|Vocalizer Plugin|Cannot process speak data. TTS_ERROR \= TTS_E_SSML_PARSE_ERROR(Code\=180)
This CVP system is working fine with Nuance OSR 3.0 and Real Speak 4.1
pleaase let me know your thoughts
Prince Christopher.J
Replied by: Hemal Mehta on 07-08-2010 10:18:45 PM
I am assuming you are getting the errro when you make the call. Assuming you have done the configuration correctly you may want to enable debugs and  look at the gateway and the vxml logs to get further insight.
Hemal
________________________________
From: Cisco Developer Community Forums [cdicuser@developer.cisco.com]
Sent: Saturday, August 07, 2010 12:16 AM
To: cdicuser@developer.cisco.com
Subject: New Message from prince christopher joseph in Customer Voice Portal (CVP) - CVP - All Versions: CVP Vocalizer Plugin|Cannot process speak data. TTS_ERROR \= TTS_E_SSML_PA
prince christopher joseph has created a new message in the forum "CVP - All Versions":
Hi All,
To respond to this post, please click the following link:
<http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2418385>
or simply reply to this email.
Replied by: Phani Venigalla on 12-04-2012 10:51:00 PM
HI Christopher,
Can you send me the configuration guide or link to configure CVP wtih TTS Vocalizer.
Phani,
Subject: Re: New Message from Phani Venigalla in Customer Voice Portal (CVP) - CVP -
Replied by: Phani Venigalla on 13-04-2012 08:48:05 AM
Guys,
Any configuration link or guide for nuance tts integration with TTS.
Looking forward.
Phani.
On 12-Apr-2012 9:51 PM, "Cisco Developer Community Forums" <
cdicuser@developer.cisco.com> wrote:
> Phani Venigalla has created a new message in the forum "CVP - All
> Versions":
> HI Christopher,
> Vocalizer.
> Phani,
> http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/5446016
