cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Phani Venigalla on 11-04-2012 04:50:10 PM
I have installed Nuance TTS vocalizer and Seechserver.
What parameters need to configure to intgrate with CVP. Both Nuance and CVP End.
Phani,
Subject: RE: CVP With Nuance TTS Vocalizer
Replied by: Phani Venigalla on 13-04-2012 10:17:56 AM
Guys,
I am stll waiting somebody can reply on my query.
I don't know why i am not getting any help.
Phani.
Replied by: Bill Webb on 13-04-2012 11:05:42 AM
Phani -
With all due respect, and I know I'm not the first to express this concern to you, this forum is meant to be an information sharing resource that may also provide "support" in the context of shared experience and ideas.
Your post is a pretty open-ended request with little to no information on what your environment is and what you're really looking for.
On the one hand, I could interpret your request as a request for a link to standard documentation. If that is the case, the document you should start with is the Configuration and Administration Guide for CVP, located here:
http://www.cisco.com/en/US/products/sw/custcosw/ps1006/products_installation_and_configuration_guides_list.html
On the other hand, based on your other numerous other posts, I could interpret your request as one for step-by-step guidance on setting up a system with CVP and Nuance, and that is clearly not what this forum should be used for.
- Bill
Replied by: Phani Venigalla on 13-04-2012 11:30:15 AM
Bill,
Thanks for sending configuration link,,,,
Phani.
Replied by: Phani Venigalla on 13-04-2012 12:49:42 PM
Bill,
I know VoiceGateway Configuration
ip host asr-en-us 10.86.177.39
ip host tts-en-us 10.86.177.39
ivr asr-server rtsp://10.86.177.39/recognizer
ivr tts-server rtsp://10.86.177.39/synthesizer
What else we need to do on CVP side to integrate with Nunace.
I am little confused about CSS configuration
content ASR add service asr1 add service asr2 primarySorryServer asr3 protocol tcp port 554 vip address 10.1.3.12content TTS add service tts1 add service tts2 primarySorryServer tts3 protocol tcp port 554 vip address 10.1.3.13
Phani.
Subject: RE: New Message from Phani Venigalla in Customer Voice Portal (CVP) - Gener
Replied by: GEOFFREY THOMPSON on 13-04-2012 01:00:05 PM
Do you really have a pair of CSS?
Geoff
Replied by: Phani Venigalla on 13-04-2012 01:05:55 PM
No I don't have
I have two nuance vocalizer servers:  Server1 and Server 2 as back up.which i need to integrate with CVP.
I have configured in NSSConfig at NSS server But I am confused at CVP End.
Replied by: Phani Venigalla on 13-04-2012 01:16:16 PM
Actually the config guide has CSS so i have cinfused.
I need to go with CVP VXML apps.
Replied by: Phani Venigalla on 13-04-2012 01:25:43 PM
Is that necessary to go with IP addresses in the following statement or we can mention Host name instead of Ip adderesses. Here these ip addresses or host name belongs to TTS servers right?
Replied by: Phani Venigalla on 13-04-2012 01:37:47 PM
Well I used Microapps to Trigger CVP application from ICM, The DN has configured on Gateway.
Replied by: GEOFFREY THOMPSON on 13-04-2012 01:10:05 PM
If you don’t have a CSS, why ask about it?
TTS is trivial. With CVP VXML apps, the only setting of importance is the RTSP.
DO debug on mrcp on the gateway to check. Standard stuff.
Geoff
Replied by: GEOFFREY THOMPSON on 13-04-2012 01:23:05 PM
CVP has lots of options, as I am sure you know.
As a beginner, concentrate on what you have and only on what you need to know for those options. Ignore the rest and come back to it later when you have the basics working.
·         Are you doing any microapps? If no, ignore that section.
·         Are you doing H.323? If no, ignore that section.
(No response is required from you for this simple advice. Please don’t answer.)
Geoff
Subject: RE: New Message from GEOFFREY THOMPSON in Customer Voice Portal (CVP) - Gen
Replied by: Hemal Mehta on 13-04-2012 02:00:05 PM
Geoff,
     We are triggering a email flood here.  You send one response and you will get back 10 questions in return.   Please be wary of this.
From: Cisco Developer Community Forums [mailto:cdicuser@developer.cisco.com]
Sent: Friday, April 13, 2012 12:23 PM
To: cdicuser@developer.cisco.com
Subject: New Message from GEOFFREY THOMPSON in Customer Voice Portal (CVP) - General Discussion - All Versions: RE: New Message from Phani Venigalla in Customer Voice Portal (CVP) - Gener
GEOFFREY THOMPSON has created a new message in the forum "General Discussion - All Versions":
Geoff
To respond to this post, please click the following link:
<http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/5454542>
or simply reply to this email.
Subject: Re: New Message from GEOFFREY THOMPSON in Customer Voice Portal (CVP) - Gen
Replied by: Phani Venigalla on 15-04-2012 09:08:56 PM
Guys,
I just wanted to check. Should we need to add nuance hostname or IP address
before configuring with CVP. In the process of nuance integration with
CVP...
Phani.
On 13-Apr-2012 11:23 AM, "Cisco Developer Community Forums" <
> answer.)
> Regards,
> Geoff
Replied by: Phani Venigalla on 16-04-2012 11:32:21 AM
I have two nuance TTS servers with xxxx host name and yyyy host name.
I want to configure both servers with CVP.
Can i give as follows
ivr tts-server rtsp://xxxx/synthesizer
ivr tts-server rtsp://yyyy/synthesizer
If i give like this how CVP know which nuance server  it should request.
Thanks.
Replied by: Ryan Hilfers on 16-04-2012 12:28:02 PM
Thanks.
Phani,  you're missing some key elements of CVP's architecture.  CVP does not select a resource, it (or vxml server) produces the vxml which references a resource... something still needs to interpret this vxml and interact with the caller... that is the VXML gateway. The gateway (functioning as the the 'IVR') then reads this Vxml document and based upon it's config, will "choose" an ASR/TTS resource. If you do not have a CSS you will need to implement some static form of 'load-balancing'.
For example, if you have 4 vxml gateways and two TTS servers that handle the same amount of volume then it would be as easy as putting: ivr tts-server rtsp://xxxx/synthesizer on two of your gateways global config and ivr tts-server rtsp://yyyy/synthesizer on your other two gateways provided you have a dial-plan that distributes the VRU legs equally across the VXML Gateways. You can also add backup asr/tts servers but remember all this config lives on the VXML gateway or alternately in the vxml properties of your studio app, either way it is interpreted in one place and that is by the Vxml gateway's voice browser. I should mention that setting backup servers is configured in OAMP along with a gateway config.
I hope that gets you in the right direction, if you need further help consult the config/admin guide or an installation guide. The answers to this integration are VERY well documented.
-Ryan
Replied by: Phani Venigalla on 16-04-2012 12:51:06 PM
Hi Ryan,
thanks for your reply.
Here we have 1 vxml gateway and 2 TTS servers, where one is primary and other is backup.
Should i need to configure both servers in Gateway Global config? and add the same in OAMP.
Phani.
Replied by: Ryan Hilfers on 16-04-2012 01:13:23 PM
Hi Ryan,
Phani.
This is an easy one, please try to figure these things out from the config guide.  Since i can quickly answer I will,  here's what you'll need on your 1 vxml gateway:
just one global config for the ivr setting:
ivr tts-server rtsp://tts-en-us/synthesizer
notice that "tts-en-us" is a hostname, we need to resolve that. This means you'll also need ip host entries:
ip host tts-en-us <IP of one TTS server>
ip host tts-en-us-backup <IP of backup TTS server>
Then in OAMP in the IVR tab for the call server you'll need to enable backup asr/tts servers.  If you're doing speech rec the configuration is nearly identical.
-Ryan
Replied by: Phani Venigalla on 16-04-2012 01:46:35 PM
hi,
Both primary and backup servers need to configure in Call server or only backup server  in the IVR tab?.
Phani.
Replied by: Ryan Hilfers on 16-04-2012 02:01:04 PM
hi,
Phani.
Have you even looked at the settings in the IVR tab?  Its a radio button, you're either telling CVP to build a retry (using the backup server) into the vxml or not. If you have more than one call server, their config in regards to ASR/TTS should be identical.
This is why I hesitated to respond to your question in the first place, not what the forum is intended for, we are once again flooding inbox's with questions/answers of little value to everyone who subscribes to this forum. Please don't reply, the answers are in the documentation.
Replied by: Phani Venigalla on 19-04-2012 04:05:31 PM
        I've installed Nuance TTS 5.0 Speech Server, and Nuance LM.
Also I have configured the below change in my NSSServer.cfg.
server.mrcp1.resource.2.url VXIString synthesizer
server.mrcp1.resource.3.url VXIString recognizer
server.mrcp1.transport.port VXIInteger 554
ivr tts-server rtsp://10.87.29.225:554/synthesizer
Still it doesnt work. I dont see any call logs in NSS logs.
Any help wold be of great help.
Phani.
Replied by: Mohamed Amine KETATA on 04-05-2012 08:17:27 AM
On Nuance Website the following products are no longer availbale :
-    Nuance Speech Server version 5.0
-    Nuance Recognizer version 9.0
-    Nuance RealSpeak version 4.5
-    Nuance License Manager version 11.4
-    Nuance RealSpeak Host Voice
Does anyone have an idea about how to get these products and some trial licenses from Nuance for a CVPI training ?
Replied by: GREG SMITH on 04-05-2012 09:56:42 AM
Mohamed,  all those versions are still available for download when I go to http;//network.nuance.com I can see them.
I would suggest it is to do with your login account at Nuance.  For example my login shows RealSpeak 4.5
download but not Vocalizer 5.0  Fortunately I use RealSpeak 4.5 and not the Vocalizer product.
I believe your login is set up by Nuance to selectively display some of their products, but not all of their products.
