cdnadmin
Level 11
Level 11
Subject: RE: making an outbound call using CVP
Replied by: Bill Webb on 19-01-2010 03:19:36 PM
Hi Justine -
I'll save you the further head-scratching that I went through...!  ;-)
Rename the service/application from "cvp_dialer" to "cvpdialer".  If you look in the Java text file, you'll notice that's how it's entered.  So there is a typo in the instructions or the Java file, depending on how you look at it.
 - Bill
This document was generated from CDN thread
Created by: Justine Joubran on 19-01-2010 02:37:47 PM
I want to try the Outbound Call feature of CVP. For this purpose, I have downloaded the sample application called "Outbound Dialing in CVP" from the "download" section of this site. I have omited all the parts that are related to the database. I am only left with the following: Start of Call - Make Call Custom Element - End Call.
I have transfered the TCL files to the gateway as described in the word document.
I have the following settings for the "make call" element:
- Outbound Destination: 575
- Calling-party: 574
I have also added the below configuration on the gateway:
voice service voip
 allow-connections sip to sip
 signaling forward unconditional
 sip
  header-passing
application
  service cvp_outbound flash:cvp_outbound.tcl
  param cvp-ob-vxml-dest 7788000
  param cvp-ob-poll-interval 15
  service cvp_dialer flash:cvp_dialer.tcl
  session
  start ob cvp_outbound
dial-peer voice 7780000 voip
 destination-pattern 778....
 session protocol sipv2
 max-conn 23
 session target ipv4:10.1.1.101  //ip address of the VXML gateway
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2004 voip
 destination-pattern 57. // ip phone extensions range
 session target ipv4:10.1.1.102
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
When I try a test call, the call reaches the "make call" element with the following error:
A VoiceXML error occurred of type "error.com.cisco.callhandoff.failure"
Any suggestions?
Thanks in advance,
Justine.
Subject: RE: New Message from Bill Webb in Customer Voice Portal (CVP) - CVP - All V
Replied by: Ranjana Narayan on 20-01-2010 05:40:29 AM
Thanks Bill, for noticing the typo. We will have it fixed !!
Ranjana.
________________________________
[mailto:cdicuser@developer.cisco.com]
Sent: Tuesday, January 19, 2010 8:50 PM
To: cdicuser@developer.cisco.com
Subject: New Message from Bill Webb in Customer Voice Portal (CVP) - CVP
- All Versions: RE: making an outbound call using CVP
Bill Webb has created a new message in the forum "CVP - All Versions":
Hi Justine -
you look at it.
- Bill
To respond to this post, please click the following link:
<http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1905
279>
or simply reply to this email.
Replied by: Mohamed Fahmy on 23-08-2010 12:51:33 PM
Did renaming the service to cvpdialer fix your problem?
Because i still get a problem, i did exactly like you did, i.e. just a MakeCall element without a database interaction, i entered static dnis and cli.
I've noticed that the date of the thread is older than the date of the application specification which means that the application is fixed but i still get a problem, the configuration is done exactly according to the specification.
Thanks in advance.
