1299
Options
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
on 01-24-2014 02:11 PM
This document was generated from CDN thread
Created by: Sylvain Cousineau on 22-04-2011 08:09:25 AM
We have a 5ESS switch that forwards calls to our Voicemail systems using AS5300 GW connected by PRI on the ISDN side. The voicemail system selects the appropriate box by the contents of the SIP Diversion field in the SIP INVITE.
For multiple re-directions (cascades and redirections), the GW always selects the contents of the last Ridirecting Number (RDN) to map to the SIP Diversion field.
However, in some cases, we would like the SIP Diversion to contain the first Ridirecting Number (OCN). In there anyway for a TCL script or any other built-in config to achieve this? We do not have any softswitch or application server in the network.
Subject: Re: New Message from Sylvain Cousineau in Voice Gateway API (VGAPI) - TCL-A
Replied by: LEON MCCALLA on 22-04-2011 09:33:14 AM
what will your criteria be for deciding whether the OCN or the RDN should be used?
Leon
Sent: Friday, April 22, 2011 8:09 AM
To: cdicuser@developer.cisco.com
Subject: New Message from Sylvain Cousineau in Voice Gateway API (VGAPI) - TCL-API: Mapping OCN ISUP IE to SIP Diversion in INVITE
Sylvain Cousineau has created a new message in the forum "TCL-API":
To respond to this post, please click the following link:
<http://developer.cisco.com/web/vgapi/forums/-/message_boards/view_message/3773066>
or simply reply to this email.
Subject: RE: Mapping OCN ISUP IE to SIP Diversion in INVITE
Replied by: Sylvain Cousineau on 22-04-2011 09:54:08 AM
Thanks for replying.
Ideally it would be maybe based on T1 controller or the Called Party Number which represents our VMS access number in this case. In any case, we are trying to get it working as a proof of concept. So just getting the OCN mapped into the Diversion for all cases is a good start.
Replied by: Sylvain Cousineau on 22-04-2011 10:41:39 AM
I've replaced the real numbers with fictional ones. We can't use the "To" since the SIP stack on the receiving application is a closed system. It's also used for other flow decision purposes later on at the application level. In the following trace, we would like Redirecting Number i = '!', 0x038F, '5197723333' to be in Diversion instead of Redirecting Number i = '!', 0x0382, '5199021111'
Mar 10 15:14:59.150: ISDN Se3/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0338
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98390
Exclusive, Channel 16
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '5191234567'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '5199122222'
Sent:
INVITE sip:5199122222@10.247.33.80:5060 SIP/2.0
Via: SIP/2.0/UDP 10.247.164.231:5060;x-route-tag="tgrp:1";branch=z9hG4bK1C213
Remote-Party-ID: <sip:'5191234567@10.247.164.231>;party=calling;screen=yes;privacy=off
From: <sip:'5191234567@10.247.164.231>;tag=FEBF208-A48
To: <sip:5199122222@10.247.33.80>
Date: Thu, 10 Mar 2011 20:14:59 GMT
Call-ID: E86E20C3-4A8911E0-8043B8BF-1C9AB394@10.247.164.231
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 3899411378-1250496992-2148270099-424009122
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1299788099
Contact: <sip:5191234567@10.247.164.231:5060>
Diversion: <sip:5199021111@10.247.164.231>;privacy=off;reason=no-answer;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 252
v=0
o=CiscoSystemsSIP-GW-UserAgent 932 2490 IN IP4 10.247.164.231
s=SIP Call
c=IN IP4 10.247.164.231
t=0 0
m=audio 18280 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Replied by: LEON MCCALLA on 22-04-2011 10:26:14 AM
I can¿t say I¿ve ever seen an RDN or a diversion number in the traces although I know such fields do exist. I¿ve done some TCL work over the years so post traces of the Q931 setup and the SIP invite and I¿ll try to cobble a short script for you.
what about if the RDN is simply dropped. Can your VMS system grab the TO instead of the DIVERSION field in the header?
Leon
Sent: Friday, April 22, 2011 9:54 AM
Subject: New Message from Sylvain Cousineau in Voice Gateway API (VGAPI) - TCL-API: RE: Mapping OCN ISUP IE to SIP Diversion in INVITE
<http://developer.cisco.com/web/vgapi/forums/-/message_boards/view_message/3773180>
Replied by: LEON MCCALLA on 22-04-2011 05:53:46 PM
I wrote a small TCL but i'm not sure how to upload it so i'll paste it below... I'm not a genius but i'm trying to help....
Leon
proc act_Setup { } {
global dest
global ani
leg setupack leg_incoming
set dest [infotag get leg_dnis]
set ani [infotag get leg_ani]
if {[infotag get evt_gtd gtd_setup] > 0} {
if {[infotag get gtd_attr_exists gtd_setup rdn.-1]} {
set callInfo(redirectNum) [object get gtd gtd_setup rdn.1.rdn]
set callInfo(originationNum) $ani
leg proceeding leg_incoming
leg setup $dest callInfo leg_incoming
proc act_CallSetupDone { } {
if { $status != "ls_000"} {
call close
proc act_Cleanup { } {
call close
# State Machine
set TopFSM(any_state,ev_disconnected) "act_Cleanup,same_state"
set TopFSM(CALL_INIT,ev_setup_indication) "act_Setup,PLACECALL"
set TopFSM(PLACECALL,ev_setup_done) "act_CallSetupDone,same_state"
set TopFSM(any_state,ev_disconnect_done) "act_Cleanup,same_state"
fsm define TopFSM CALL_INIT
Replied by: LARIS BENKIS on 27-07-2011 03:19:53 PM
I've tried to extract the OCN without success
To do this I create the gtd handle "gtd_setup":
set ret [ object create gtd gtd_setup IAM ]
puts "act_Setup gtd_setup create return $ret"
I then extract the ocn information:
set ocn_exists_num [object get gtd gtd_setup ocn.-1.dat]
puts "act_Setup ocn_exists_num $ocn_exists_num"
The debugs show the incoming call and the OCN parameter set properly. A debug error message (ERROR: GTD_STATUS_PARM_NOT_FOUND) is generated on the object get call. I'm wondering if the <attribute_name> parameter on the call "ocn.-1.dat" is correct. There doesn't appear to be any documentation online about how to form attribute_name other than two examples in the programming guide. The .dat suffix on the attribute seems pretty arbitrary so without some explanation on how the attribute name is constructed getting it to work is a matter of lucky guessing.
Jul 27 10:21:14.436: ISDN Se3/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0399
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
Facility i = 0x9F8B0100A11002010102010080084C2042454E4B4953
0xA11002010102010080084C2042454E4B4953
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = L BENKIS
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '5556809285'
Called Party Number i = 0xA1, '5555090003'
Redirecting Number i = '!#', 0x8F, '5559023071'
Redirecting Number i = '!', 0x0382, '5559023074'
Jul 27 10:21:14.436: ISDN Se3/1:23 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5149023074 reason 2 cnt -1 plan 1 type 2 pres 0
Jul 27 10:21:14.440: ISDN Se3/1:23: Built a GTD of size 267 octets for ISDN message type 0x5
Jul 27 10:21:14.440: tsp_ccrawmsg_encap: calling cdapi_find_tsm
Jul 27 10:21:14.440: cdapi_find_tsm: Found Tunnelled Signaling Msg with GTD: PROT_PTYPE_GTD
Jul 27 10:21:14.440: cdapi_find_tsm: Found a gtd msg of length 267:
Jul 27 10:21:14.440: gtd msg = "IAM,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
CPN,04,,1,5555090003
CGN,04,,1,y,4,5556809285
OCN,04,1,n,5559023071
FDC,RNI,rr,5,0f
RGN,04,1,y,5559023074
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
GCI,84ed43d0b79211e0803f001bd51b4e16"
Jul 27 10:21:14.440: ccGTDExtractParm: Starting
Jul 27 10:21:14.440: tunnelledPtype = 2
Jul 27 10:21:14.440: gtdInstance = 0
Jul 27 10:21:14.440: gtdBitMap = 0xFFFFFFFF
Jul 27 10:21:14.440: ccGTDExtractParm: TunnelledContent has GTD message
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
Jul 27 10:21:14.440: ccGTDExtractParm: GTD Parm OCN obtained
Jul 27 10:21:14.440: ccGTDExtractParm: GTD Parm CPC obtained
Jul 27 10:21:14.440: ccGTDExtractParm: GTD Parm FDC obtained
Jul 27 10:21:14.440: ccGTDExtractParm: GTD Parm TMR obtained
Jul 27 10:21:14.440: ccGTDExtractParm: GTD Parm PRN obtained
Jul 27 10:21:14.440: ccMapGCItoGUID: GTD Parm GCI present: 84ed43d0b79211e0803f001bd51b4e16
Jul 27 10:21:14.444: Have gtd msg, length=267:
Jul 27 10:21:14.444: gtd msg = "IAM,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
Jul 27 10:21:14.448: //112//TCL :/tcl_PutsObjCmd: act_Setup gtd_setup create return 1
Jul 27 10:21:14.448: gtd_get_parm_field(): ERROR: GTD_STATUS_PARM_NOT_FOUND
Jul 27 10:21:14.448: //112//TCL :/tcl_PutsObjCmd: act_Setup: ocn_number_all
Jul 27 10:21:14.448: Have gtd msg, length=267:
Jul 27 10:21:14.448: gtd msg = "IAM,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
Replied by: Yaw-Ming Chen on 27-07-2011 03:31:44 PM
The following fields are defined for the Original Called Number (OCN).
Field Name Type Comments Assoc. enum/value
noa number Nature of address gtdMNoaType
npi number Number plan indicator gtdMNpiType
pi number Presentation indicator gtdMPiType
num Null terminated string Telephony number Alphanumeric char string (see telephone-number, ENG-110144, for syntax, up to 32 chars)
Replied by: LARIS BENKIS on 27-07-2011 03:43:44 PM
So how would the num parameter be extracted?
If I set the attribute_name parameter a few different ways (trying for the lucky guess here because its not documented) I get:
ocn.-1.dat - script generates a debug error message ERROR: GTD_STATUS_PARM_NOT_FOUND
ocn.num - script crashes with message "Invalid instance specification num"
ocn.num.dat - script crashes with message "Invalid instance specification num"
Laris
Replied by: LARIS BENKIS on 28-07-2011 01:47:31 PM
set ocn_exists_num [object get gtd gtd_setup ocn.-1.dat] - script generates a debug error message ERROR: GTD_STATUS_PARM_NOT_FOUND
set ocn_exists_num [object get gtd gtd_setup ocn.num] - script crashes with message "Invalid instance specification num"
set ocn_exists_num [object get gtd gtd_setup ocn.num.dat] - script crashes with message "Invalid instance specification num"
Laris
Replied by: Raghavendra Gutty Veeranagappa on 29-07-2011 02:38:11 AM
Hi Laris,
Please try with following code and print values.
set gtdHandle [infotag get evt_gtd gtd_iam]
if {$gtdHandle > 0} {
if {[infotag get gtd_attr_exists gtd_iam ocn.-1]} {
set ocn_noa [object get gtd event_gtd ocn.1.noa]
set ocn_npi [object get gtd event_gtd ocn.1.npi]
set ocn_num [object get gtd event_gtd ocn.1.#]
Raghavendra
Replied by: LARIS BENKIS on 29-07-2011 10:37:25 AM
Thanks Raghavendra,
I got it to work with this code:
set ret [ object create gtd gtd_iam IAM ]
set ocn_noa [object get gtd gtd_iam ocn.1.noa]
puts "act_Setup ocn_noa $ocn_noa"
set ocn_npi [object get gtd gtd_iam ocn.1.npi]
puts "act_Setup ocn_npi $ocn_npi"
set ocn_num [object get gtd gtd_iam ocn.1.#]
puts "act_Setup ocn_num $ocn_num"
I'm a little confused - what is the difference between the gtdhandles returned by "object create gtd" and "infotag get evt_gtd"?
Is there any documentation on the structure of the attr_instance parameters that are used by "object get gtd"? The documentation I've seen gives some examples without really explaining them.
Laris
Leon
Standard = CCITT
Invoke Id = 1
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 252
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Leon
Leon
global dest
global ani
call close
call close
# State Machine
Standard = CCITT
Invoke Id = 1
Name = L BENKIS
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
FDC,RNI,rr,5,0f
RNI,,3,,2
FDC,RNI,rr,5,02
CPC,09
FCI,,,,,,,y,
Laris
Laris
Hi Laris,
Raghavendra
Hi Laris,
Raghavendra
Thanks Raghavendra,
Laris
Labels:
