cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: haloha haloha on 31-05-2012 06:04:36 AM
i read the debit card.tcl and there are 3 variable which i am not clear
proc init { } {
    global param1
    global beep
    global param2
    global param3
    global pound
    set beep 0
    set pound 0
    set param1(interruptPrompt) true
    set param1(abortKey) *
    set param1(terminationKey) #
    set param2(interruptPrompt) true
    set param2(abortKey) *
    set param2(terminationKey) #
    set param2(dialPlanTerm) true
    set param3(interruptPrompt) true
    set param3(abortKey) *
    set param3(terminationKey) #
could you please explain how to use of param1, param2, param3
Subject: RE: need help on variable of tcl debit card
Replied by: Raghavendra Gutty Veeranagappa on 31-05-2012 08:58:16 AM
Hi ,
here is the params description for more information you can refer the tcl programming guide in below link.
http://developer.cisco.com/web/vgapi/resources
param(interruptPrompt)—Whether to interrupt the prompt when a key is pressed. Possible values are true and false. The default is false.
param(dialPlanTerm)—Match incoming digits against a dial plan and, even if the match fails,continue to collect the digits until the termination key is pressed or a digit timeout occurs.Possible values are true and false. The default is false.
param(abortKey)—Key to abort the digit collection. The default is none.
param(terminationKey)—Key that terminates the digit collection. The default is none.
Ragahvendra
Replied by: haloha haloha on 31-05-2012 09:36:18 PM
Hi Raghavendra
thank you for your answer
