Created by: ROD TAGUCHI on 22-06-2012 03:19:03 PM Clean install for Albani with SR1 upgrade. Having issues with NFS automount. Base 3.0 and SR1 continues to have the same issue. Automount does not mount NFS mount for any directory including diagnostics. I can manually mount the directory and have permission to touch files, however the /mnt/auto/diagnostics mount does not work. I created the mount point directories using the Quad 2.5.2 node and set permissions there before installing Albani. For both systems i am using the subdirctory under the root mount. I.e. NFS:/vol/quad_sata/demo3 Thanks, Rod
Subject: RE: NFS automount issue Replied by: Manuel Michel on 22-06-2012 05:00:53 PM Albani stores logs in the director at /var/logs or /opt/logs - you need to check, I have the path not in mind.
Subject: RE: NFS automount issue Replied by: ROD TAGUCHI on 22-06-2012 05:14:19 PM Nice,
/opt/logs
Thanks Rod
Subject: Re: New Message from ROD TAGUCHI in WebEx Social Developer - WebEx Social 3 Replied by: Christopher Chandler on 22-06-2012 05:18:36 PM Also:
