cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Reinhard Schloeglhofer on 05-03-2013 06:01:12 AM
Hello, I have developed an application which needs to set a call variable which is received from a customer service after the established call event. The CTIOS log shows the following entry: Trace: CRITICAL: ServiceQueuePostThread caught exception while processing a request[eSetCallDataRequest], GetLastError() returned 0. This is the Java code:             Arguments callData = currentcall.GetCallData();             callData.SetValue(CtiOs_IKeywordIDs.CTIOS_CALLVARIABLE7, value);             errorcode = currentcall.SetCallData(callData); errcode is always 1 (OK) but 0 (FAILED) in the CTIOS log. Does anyone have an idea why the setting of a call variable fails ? Thanks in advance Best regards Reinhard
Subject: RE: New Message from Reinhard Schloeglhofer in Computer Telephony Integrati
Replied by: David Lender on 05-03-2013 07:51:49 AM
Are you receiving either a SetCallDataConf or a onControlFailureConf?   What is in your CTIOS client log?  The CTIOS Server log?  Is currentcall set correctly?  If so, try logging callData arguments array to verify the get is working correctly.
Replied by: Reinhard Schloeglhofer on 05-03-2013 10:44:56 AM
Hi David, I have now attached the different logs and the source code. The setCallDataConf or ControlFailureConf are not received. The dumped call data are ok (see CallVariable7)
Replied by: David Lender on 05-03-2013 11:02:03 AM
Your application is using a monitor (filter) mode connection.  Monitor mode connections are for receiving events only.  You are not allowed to control calls or agents or set call data from a monitor mode session.
Subject: RE: Setting call variables in CTIOS application in monitor mode
Replied by: Reinhard Schloeglhofer on 06-03-2013 12:41:51 AM
Thank you for this information. I did not find anything about this restriction in the CTIOS documentation. But from the wording point of view it is clear now. I think i will need to use supervisor mode.
