cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Gionata Navarra on 13-10-2010 09:29:23 AM
Good morning,
I have no idea if it's right to post here my thread, anyway I try to post my question.
I've updated a Cisco 7960 with sip firmware and deployed to it new custom services.
When
I try to use these new services I receive an xml parse error from the
phone. I've noticed that the problem is due to softkeys added in the
code of new services and removing softkeys services run well.
I'm following this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/5_1/english/programming/guide/ip5_1ch2.html#wpxref1047782
Maybe sip firmware doesn't support this kind of xml object?
Thank you in advance
Gionata Navarra
Subject: RE: sip firmware 7960
Replied by: David Staudt on 13-10-2010 02:36:41 PM
Due to resource constraints, the 7940/60 phones running SIP loads do not support the full XML services implementation.  The main features missing are CiscoIPPhoneExecute and custom soft keys, there are a few others - the feature set is consistent with what is documented in the '3.0 IPPS Application Development Notes' here: http://developer.cisco.com/web/ipps/docs
Replied by: Gionata Navarra on 14-10-2010 03:20:48 PM
This seems to be a problem because these services are deployed on 7960 with sip firmware installed and custom softkeys are essential.
Do you know if any upgrades of sip firmware resolve this issue? or any alternative solutions?
Thank you.
Gionata Navarra
Replied by: David Staudt on 14-10-2010 06:02:44 PM
Unfortunately these models just do not have the capabilities (mostly memory) to add any additional features, and development for them is end-of-life.
Only options are to use a SCCP firmware load or upgrade to a newer phone model.
Replied by: Gionata Navarra on 18-10-2010 06:54:29 AM
Thank you very much.
Gionata Navarra
