cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Jean Lofrano on 13-07-2011 08:50:12 AM
The router debug is bellow...
*Jul 12 18:35:24.717: //55//TCL :/tcl_PutsObjCmd: IT7: playing audio Welcome
*Jul 12 18:35:24.717: //55//TCL :/tcl_PutsObjCmd: IT7: Caller ID 7081
*Jul 12 18:35:24.721: //55//TCL :/tcl_PutsObjCmd: IT7: Audio played Welcome
*Jul 12 18:35:28.773: //55//TCL :/tcl_PutsObjCmd: IT7: playing question 1
*Jul 12 18:35:28.773: //55//TCL :/tcl_PutsObjCmd: IT7: played question 1
*Jul 12 18:35:28.773: 2
*Jul 12 18:35:31.549: //55//TCL :/tcl_PutsObjCmd: IT7: collecting question 1
*Jul 12 18:35:31.549: //55//TCL :/tcl_PutsObjCmd: IT7: collected question 1
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: try to send web
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: cpf cd_005
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: starting web
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: URL Validacao #1        72.20.1.15:9778/URA/ValidarCPF?telefoneorigem=7081&cpf=22784639185
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: sent web
*Jul 12 18:35:42.629: //55//TCL :/tcl_PutsObjCmd: IT7: end try to send web
*Jul 12 18:35:45.281: //55//TCL :/tcl_PutsObjCmd: IT7: processing web return
*Jul 12 18:35:45.281: //55//TCL :/tcl_PutsObjCmd: IT7: Web Return:16494:
*Jul 12 18:35:45.281: //55//TCL :/tcl_PutsObjCmd: IT7: ------> Return OK - playi        ng question 2
*Jul 12 18:35:52.549: //55//TCL :/tcl_PutsObjCmd: IT7: collect question 2
*Jul 12 18:35:52.549: //55//TCL :/tcl_PutsObjCmd: IT7: collected question 2
*Jul 12 18:36:00.533: //55//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tc        l modulespace. code=1 code=ERROR
*Jul 12 18:36:00.533: TCL script failure
        Result:
                         can't read "UserKey": no such variable
*Jul 12 18:36:00.533:   TCL script failure errorInfo:
    while executing
"set URL http://$WebServer/URA/ValidarTelefone?telefoneorigem=$CallerID&user_key        "$UserKey&telefone=$Response2
    (procedure "Action2" line 17)
    invoked from within
"Action2"
I need to use the Webreturn value in the action 2... but it is not working....
proc ActionPlayQuestion1 { } {
    puts "IT7: playing question 1"
    media play leg_incoming "flash:/digite-cpf1.wav"
    puts "IT7: played question 1"
proc ActionPlayQuestion1Again { } {
    puts "IT7: playing question 1 again"
    media play leg_incoming "flash:/digite-cpf2.wav"
    puts "IT7: played question 1 again"
#coleta os digitos da questao 01
proc ActionCollectQuestion1 { } {
    puts "IT7: collecting question 1"
    set Question1Param(interruptPrompt) true
    set Question1Param(terminationKey) #
    set Question1Param(maxDigits) 11
    set Question1Param(dialPlan) true
    set Question1Pattern(1) "..........."
    leg collectdigits leg_incoming Question1Param
    puts "IT7: collected question 1"
#send collected digits through web
proc Action1 { } {
    puts "IT7: try to send web"
    global WebServer
    global Response1
    global WebReturn
    global CallerID
    set StatusCollectDigits [infotag get evt_status]
    puts "IT7: cpf $StatusCollectDigits"
    #matched pattern
    if {$StatusCollectDigits == "cd_005"} {
       puts "IT7: starting web"
       set Response1 [infotag get evt_dcdigits]
       set URL http://$WebServer/URA/ValidarCPF?telefoneorigem=$CallerID&cpf=$Response1
        # http://172.20.1.15:9778/URA/ValidarCPF?telefoneorigem=666&cpf=22784639185
    puts "IT7: URL Validacao #1 $URL"
       ::httpios::geturl $URL -command httpCallback1
       puts "IT7: sent web"
    } else {
    puts "IT7: error - playing error audio"
    media play leg_incoming "flash:/informacaoincorreta.wav"
    fsm setstate PLAYEDWRONG1
    puts "IT7: error - played error audio"
    puts "IT7: end try to send web"
proc httpCallback1 { token } {
   puts "IT7: processing web return"
   if {[::httpios::status $token] == "ok"} {
      set WebReturn [string trim [::httpios::data $token]]
   } else {
      set WebReturn 0
   puts "IT7: Web Return:$WebReturn:"
   if { $WebReturn != "0" } {
      puts "IT7: ------> Return OK - playing question 2"
      media play leg_incoming "flash:/digite-dn1.wav"
     fsm setstate PLAYEDQUESTION2
   } else {
      puts "IT7: wrong information, lets try again"
#play question 2, second time
proc ActionPlayQuestion2Again { } {
    puts "IT7: playing question 2 again"
    media play leg_incoming "flash:/digite-dn2.wav"
    puts "IT7: played question 2 again"
#coleta os digitos da questao 02
proc ActionCollectQuestion2 { } {
    puts "IT7: collect question 2"
    set Question2Param(interruptPrompt) true
    set Question2Param(terminationKey) #
    set Question2Param(maxDigits) 10
    set Question2Param(dialPlan) true
    set Question2Pattern(1) ".........."
    leg collectdigits leg_incoming Question2Param
    puts "IT7: collected question 2"
proc Action2 { } {
    global WebServer
    global Response2
    global CallerID
    #matched pattern
       set Response2 [infotag get evt_dcdigits]
  set URL http://$WebServer/URA/ValidarTelefone?telefoneorigem=$CallerID&user_key=$WebReturn&telefone=$Response2
Subject: RE: TCL issue : Can´t read .. no such variable
Replied by: Jean Lofrano on 13-07-2011 08:51:58 AM
So,
How can I to use a proc1´s webreturn value in another proc???
thanks...
Replied by: Raghavendra Gutty Veeranagappa on 13-07-2011 09:15:29 AM
Hi Jean,
Please add  "global WebReturn" in your Action2 procedure.
thanks,
Raghavendra
Replied by: Jean Lofrano on 26-07-2011 04:37:45 PM
Ok.. thanks....
yawming
Did you configure   BackSecs in IOS config ? param BackSecs ...
Maybe use something different in IOS config as well like "param Back_Secs xxx" then
set BackSecs [infotag get cfg_avpair Back_Secs]
Alfred Johnson
Sorry, but I found a typograhical error that was the cause.  I typed BackSecs as Backsecs in one of my global statements.  I deleted my comment after I found the typo, but I guess you saw my comment before I erased it.
Thanks.
