cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: SEAN NILSEN on 27-01-2009 04:44:25 AM
Has anyone successfully utilized a WebServices element in a CVP 4.1 environment?
My problem is that while I can load the WSDL into Studio, and I can configure the Request and Response, I get the following error when actually calling the Element:
The error was: SOAP 1.1 Binding with null invocation parameter is not allowed with HTTP POST Request Method in MESSAGE mode The error was:
The root cause was: javax.xml.ws.WebServiceException: SOAP 1.1 Binding with null invocation parameter is not allowed with HTTP POST Request Method in MESSAGE mode
com.audium.server.AudiumException:
I know the error LOOKS like I'm missing a parameter, but really, there's only one and I've even statically set it and am considering building it statically in another webservice just to see what it says when I don't have to pass ANY parameters.
Has anyone run across this before (and hopefully resolved it)?
Subject: Re: WebServices Element and .Net Webservices
Replied by: Janine Graves on 27-01-2009 06:48:45 PM
Someone posted the same question a month or two back but in a 7.0.1
environment.
They then posted that the problem was resolved when they updated their
client and server system to 7.0.2 patch.
You should find out if the same patch exists for 4.1
willwatts
Level 5
Level 5
I'm using CVP 9.0(1) and I see the same error.  In particular I'm using theHttpPost Port from my WSDL and I get the errror: element,error,The error was: SOAP/HTTP Binding in MESSAGE is not allowed with a null invocation argument. Must be: PAYLOAD
Now I switch the Port to be Soap instead of HttpPost and it works fine.
