This document was generated from CDN thread
Created by: Jon Koch on 06-10-2009 05:01:55 PM
I am using the latest Crestron module (MXP Full Control v3.2) to control a 6000 MXP. When I try and move the camera, it moves in "steps" and is not a smooth movement like when using the Tandberg remote. Is there something I have overlooked? I have tried different baud rates and different control cables. The 6000 is currently running 7.2 software. Any help would be appreciated.
Subject: RE: 6000 MXP Camera Control
Replied by: Roger Boe on 08-10-2009 11:33:30 AM
Hi Jon,
We do not have any knowledge about this module. I believe it's made by Crestron and hence you would need to contact them about this problem.
Edit:
We will let our main Crestron programmer have a look at this. He is currently on vacation so this will take some time.
Best regards
Roger
Replied by: Jon Koch on 08-10-2009 03:45:49 PM
Thanks Roger.
It isn't a huge problem, but I wanted to see if anyone else was experiencing the same problems. I'll keep the post up just on the remote chance that someone has. Most of our customers like using the Tandberg remote vs the touchpanel anyway.
Replied by: Bryan Mitchell on 08-10-2009 07:46:20 PM
On the Crestron module, which signals are you using to move the camera?
Bryan
Replied by: Jon Koch on 14-10-2009 08:10:32 PM
I am using the regular camera controls and not the ir emulation controls. I tried using each of them but I still get the same result.
Jon
Replied by: David Bruun-Lie on 21-10-2009 01:43:21 PM
Hi Jon,
I have just tried this myself using the same module. I have tested it on a 6000MXP (F8.0) with a wave camera and the camera moves smoothly here.
Could you tell me what kind of camera you have connected - and is it connected directly to the codec, is it on a visca chain, is it connected via a TANDBERG Video Switch?
David
Replied by: Jon Koch on 22-10-2009 08:05:24 PM
Hey David,
I am using a PrecisionHD camera. I have it connected directly to the Data 2 port. Maybe the Crestron module doesn't play well with the HD camera.
Jon
Replied by: David Bruun-Lie on 23-10-2009 10:51:19 AM
Hi again Jon,
Its nothing to do with the Crestron module not playing well with the HD camera. The module just tells the codec to start moving the camera in a given direction and then sends a stop command so unless your module for some reason pulses the camera move digital signal the camera should move smoothly.
I'll get hold of a PrecisionHD camera and test it with my codec and see if I am able to reproduce the jerky movements...
David
Replied by: Jon Koch on 27-10-2009 03:40:54 PM
Thanks David. I have been pulling my hair out trying to figure out what it could be.
Jon
Replied by: Mark Corlett on 12-11-2009 06:22:40 PM
Hi All,
We see that this problem is ticked as being resolved, but what was the resolution?
We also are pulling our hair out.
We are using the 3.2 Crestron module, but the camera just steps slowly away..tick...tick...tick...
Replied by: David Bruun-Lie on 16-11-2009 12:49:47 PM
Mark,
what happens when you issue the command "xCommand cameramove camera:1 direction:left" and "xCommand cameramove camera:1 direction:right" directly on the codecs serial port or telnet port? Is it still jerky?
Replied by: Bart Van Eynde on 28-02-2011 11:40:01 AM
Hello Mark,
One of our customers has the same issue. When they try to move their camera (PrecisionHD) or they try zoom in/out via the Crestron module it goes in steps (very slow).
They already tried the commands that you mentioned in your previous response but it will gave the same behavior, the slow steps.
Do you have already some experience with the PrecisionHD camera in combination with the Crestron control module? Thank you
Bart
Replied by: David Bruun-Lie on 02-03-2011 11:02:18 AM
Bart,
we have not found anything that indicates that this has anything to do with the Crestron module.
What firmware version are they running on the 1) codec 2) camera (firmware on camera(s) can be found by executing "xstatus camera" on the api of the codec.
David
