cdnadmin
Community Member
This document was generated from CDN thread
Created by: MARK KNEPPER on 19-03-2009 06:34:25 PM
Have an application that places a call to a 7921 and is supposed to play a message when the user answers -- works for 79xx except for the WiFi phones.  Thinking maybe it is a codec issue?
Mark
Subject: RE: 792x Audio Problem
Replied by: David Staudt on 19-03-2009 10:43:08 PM
What exactly are the symptoms?
What are the specific codec parameters (encoding, bitrate, sample size, ulaw/alaw, etc.)?
Is the audio in the call RTP stream or via an XML services audio command?
Is broadcast involved?
