melad
Community Member
Question
U-Boot 1.1.4.v5.3 (Jan 31 2013 - 12:54:33)
DRAM: 128 MB
CPU: 560 MHz
Top of RAM usable for U-Boot at: 88000000
Reserving 283k for U-Boot at: 87fb8000
Reserving 144k for malloc() at: 87f94000
Reserving 44 Bytes for Board Info at: 87f93fd4
Reserving 36 Bytes for Global Data at: 87f93fb0
Reserving 128k for boot params() at: 87f73fb0
Stack Pointer at: 87f73f98
Now running in RAM - U-Boot at: 87fb8000
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x14
flash size 1MB, sector count = 64
Flash: 1 MB
Fetching MAC Address from 0x87fe3908
eth0: 44:03:a7:e5:19:6e
ATHRSF1_PHY: Port 4, Negotiation timeout
Ethernet link down
eth0
Ether initialization ok!
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Communications, Ltd.
Ath Nand ID[87ff117c]: 2c:f1:80:95:02
ONFI MICRON MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
====== NAND Parameters ======
sc = 0x87ff1158 bbt = 0x87f98360 bbt_size = 0x100 nf_ctrl = 0x344
page = 0x800 block = 0x20000 oob = 0x40
size = 128MB
Setting 0xb8116290 to 0x2c582d0f
Test Size=0x8000000, Start!!
RAM test complete!
PTD Init
MAC address check ok!
boot method:3
Hit "ESC" to stop autoboot: 0
Uncompressed size: 319299 = 0x4DF43
Loading .text @ 0x84000000 (205088 bytes)
Loading .rodata @ 0x84032120 (38400 bytes)
Loading .data @ 0x8403b720 (3200 bytes)
Loading .data.rel.local @ 0x8403c3a0 (992 bytes)
Loading .data.rel @ 0x8403c780 (124 bytes)
Loading .data.rel.ro.local @ 0x8403c7fc (92 bytes)
Loading .data.rel.ro @ 0x8403c858 (960 bytes)
Clearing .bss @ 0x8403cc20 (161112 bytes)
Clearing .scommon @ 0x84064178 (60 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 2
total2 2
success found all blocks
start end 15 15
found in range
high low end 498 497 15
Xmodem file system is available.
mifs[0]: 1 files, 2 directories
mifs[0]: Total bytes : 131334144
mifs[0]: Bytes used : 10240
mifs[0]: Bytes available : 131323904
ú )sÿ0]: mifs fsck took 0 seconds.
bå"'Âôc(dï"0ç}ÿ`
aì]Ãÿ
!áououmkuk
Answer
Leo Laohoo
Contact Cisco TAC and organize for an RMA. (The firmware of the new APs are so much "locked down" any small issue, particularly if the OS is corrupt, requires TAC assistance that it is better to just organize an RMA.)
Tomahawk1
Frequent Visitor
Frequent Visitor
@melad wrote:
Question
DRAM: 128 MB
CPU: 560 MHz
Flash: 1 MB
Ethernet link down
eth0
size = 128MB
RAM test complete!
PTD Init
boot method:3
Valid buffers 2
total2 2
start end 15 15
found in range
bå"'Âôc(dï"0ç}ÿ`
aì]Ãÿ
!áououmkuk
Answer
