This document was generated from CDN thread
Created by: Janine Graves on 01-12-2006 03:22:43 AM
Have your customers had as much trouble with their Studio activations as the folks here at UHG have had? These guys are telling me of the many, many hours they've spent with installs and uninstalls and re-installs because of Studio license (or activation) keys that have either expired or been incorrect.
Can you tell me how the activation works? I know that when one starts Studio, it assigns a System ID that is used in the activation. But, would the System ID change on a laptop if I were to uninstall and then re-install Studio?
The whole process seems mysterious and cumbersome. The pushback I'm hearing is that the development tool should be made easier to license and use, and that Audium should charge for the runtime licenses.
I'm wondering how this will work in a classroom environment where we'll be installing and uninstalling and re-installing with each class.
Thanks, Janine
Subject: RE: Activation problems
Replied by: Michael Bochynski on 01-12-2006 02:19:59 PM
Janine,
Thanks for the feedback, we appreciate it as it makes our software better.
The new licensing, introduced in Studio 5.0, replaces the zip files we were previously sending. This system is designed to make things easier for developers to use the software.
However, Studio 5.0 has the first implementation of the new system. Based on the feedback we got from users, we have improved the system and as of Studio 5.1.3 we removed a lot of minor nuisances.
System ID is designed to replace IP addresses we previously required. System ID is an unique alphanumeric string that represents a particular machine. However, Studio 5.0 was especially picky with laptops, where minor changes with the hardware would affect, and change, the System ID.
As of Studio 5.1.3, we have improved the System ID generation, and changed it to be MAC address based. This greatly improves the process and we have got a lot of positive feedback about the changes.
UHG uses both Studio 5.0 and Studio 5.1, due to some Gateway Adapter availability. However, I believe this issue is already solved and they should be able to upgrade to Studio 5.1.
AS a separate note, I am very curious why they need to uninstall and re-install Studio every time they need to change the license.
Any change to the license, automatically obtained from the server, can be done with two click from Studio menu options or, if an internet connection is not available, by simply copying a block of text into one field in the Studio menu.
Note that the Installation Key is never expires and is required to obtain the actual license. Installation Key does not have any licensing information besides the product is is issued for. So Studio installation Key will not work with Call Services and vice versa.
Should they need to change the Installation Key, it could be easily done as well. Note that it is not changeable from the GUI options, since in normal situations you do not change the Installation Key, you only obtain the license from the server.
However, should you need to change it, it is as simple as deleting a file on the file system. You can navigate to the following folder:
Studio\eclipse\plugins\com.audiumcorp.studio.license_5.1.0\license
And delete both InstallationKey and License Key. Next time you start Studio, it will ask you enter your new Installation Key.
To sum up, we strongly advice customers to upgrade to Studio 5.1.3, since we've addresses all the issues related to System ID generation and invalidation of the license.
hope it helps,
Michael
Replied by: Michael Bochynski on 01-12-2006 02:34:29 PM
Janine,
Small correction. The folder name I gave in the previous post is for Studio 5.1. The correct name in Studio 5.0 is:
Studio\eclipse\plugins\com.audiumcorp.studio.license_5.0.0\license
Michael
