cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Chris Hartley on 26-05-2009 11:59:30 PM
Hi all,
Looking to add an IP Phone Service to a device. Thought it could be done via updatePhone but having some issues. Can this be done using updatePhone and if so any sample code to add an IP Phone Service to a device that already has a number of IP Phone Services assigned?
If not possible any other AXL elements i could use or a sample SQL insert\update that would provide this functionality.
Chris
Subject: RE: Add IP Phone Service to a device using AXL
Replied by: Chris Hartley on 27-05-2009 01:09:29 AM
Sorry should have stated it was CUCM 7.x
Replied by: Chris Hartley on 27-05-2009 01:48:17 AM
OK after some trial and error i found the issue. Seems the service section needs to be in the format
"<services><service><telecasterService
uuid="{pkid}"/><name>Blah</name><url>http://blah/default?name=#DEVICENAME#</url></service></services>"
