cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mohamad Atef on 23-11-2010 12:27:06 PM
I was trying to add a new user by the use of java code like:
   AddUserReq req = new AddUserReq();
   XUser user = new XUser();
   user.setUserid(userId);
   user.setFirstname(firstName);
   user.setLastname(lastName);
   user.setPassword(password);
   req.setNewUser(user);
   stub.addUser(req);
where stub is an AXLAPIBindingStub.
and I'm getting this error:
Exception in thread "main" AxisFault
 faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Client
 faultSubcode:
 faultString: EndUser cannot be inserted because Corporate LDAP directory is the sync master. Add users in the corporate directory.
 faultActor:
 faultNode:
 faultDetail:
        {http://www.cisco.com/AXL/API/6.1}Error:<axl:code>4302</axl:code><axl:message>EndUser cannot be inserted because Corporate LDAP directory is the sync master. Add users in the corporate directory.</axl:message><request>addUser</request>
        at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:222)
        at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:129)
        at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087)
        at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
        at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
        at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
        at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
        at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
        at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
        at org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
        at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696)
        at org.apache.axis.Message.getSOAPEnvelope(Message.java:435)
        at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnderstandChecker.java:62)
        at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
        at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
        at org.apache.axis.client.Call.invoke(Call.java:2767)
        at org.apache.axis.client.Call.invoke(Call.java:2443)
        at org.apache.axis.client.Call.invoke(Call.java:2366)
        at org.apache.axis.client.Call.invoke(Call.java:1812)
        at cisco.www.AXLAPIService.AXLAPIBindingStub.addUser(AXLAPIBindingStub.java:13545)
        at axltest.AXLManipulator.addEnduser(AXLManipulator.java:194)
        at axltest.Main.main(Main.java:29)
        Java Result: 1
if anyone can help me , let me know
Subject: Re: New Message from Mohamad Atef in Administration XML (AXL) - Administrat
Replied by: Johannes Krohn on 23-11-2010 12:58:49 PM
If Communciations Manager is configured to sync users from a LDAP directory
you cannot add users on CUCM directly; they have to be added to the LDAP
directory and then get added to Communications Manager with the next sync.
Can you pls. check whether LDAP user import/sync is configured on your
Communications Manager?
Subject: RE: Re: New Message from Mohamad Atef in Administration XML (AXL) - Adminis
Replied by: Mohamad Atef on 23-11-2010 01:08:25 PM
and how can I check that?
Replied by: Johannes Krohn on 23-11-2010 01:37:49 PM
In the Communications Manager Administration GUI go to System/LDAP/LDAP
System and look for the ³Enable Synchronizing from LDAP Server² option. If
this is enabled more details can be found in System/LDAP/LDAP Directory .
Replied by: Mohamad Atef on 24-11-2010 11:40:35 AM
thanks the problem is solved by your help
Replied by: Doug Kartio on 14-04-2011 10:16:14 AM
So does just turning off the LDAP sync, allow you to add users directly to CM  through the soap call?
