cdnadmin
Community Member
Subject: RE: AddPhone: A character to numeric conversion process failed
Replied by: Salim Guerid on 01-11-2013 03:19:05 AM
Hi Dennis,
Thanks for your answer.
No I have not tried to do so. I will do it shortly and post the result. I was hopping that it was possible to identify the faulty variable type from the request.
KR
Salim
This document was generated from CDN thread
Created by: Salim Guerid on 01-11-2013 12:30:59 AM
Hi all,
I am trying to add a new CSF device using the following code:
 1AddPhoneReq req = new AddPhoneReq();
 2req.phone = new XPhone();
 3req.phone.name = "CSF4" + userID;
 4req.phone.description = site + " CSF " + userID + "-" + extension;
 5req.phone.devicePoolName = new XFkType() { Value = siteDevicePool };
 6req.phone.commonDeviceConfigName = new XFkType() { Value = site + "-Device Config" };
 7req.phone.phoneTemplateName = new XFkType() { Value = PhoneButtonTemplate };
 8req.phone.commonPhoneConfigName = new XFkType() { Value = site + "-Common Phone Profile" };
 9req.phone.callingSearchSpaceName = new XFkType() { Value = stdLineCSS[0] + "-" + site };
10req.phone.locationName = new XFkType() { Value = site };
11req.phone.sipProfileName = new XFkType() { Value = stdCSFSIPProfile };
12req.phone.securityProfileName = new XFkType() { Value = DeviceSecurityProfile };
13req.phone.subscribeCallingSearchSpaceName = new XFkType() { Value = stdLineCSS[0] + "-" + site };
14req.phone.ownerUserName = new XFkType() { Value = userID };
15
16// Values added to try to address the issue
17req.phone.packetCaptureDuration = "0";
18req.phone.networkHoldMohAudioSourceId = "1";
19req.phone.userlocale = "";
20req.phone.networkLocale = "";
21req.phone.userHoldMohAudioSourceId = "1";
22req.phone.idleTimeout = "5";
23req.phone.versionStamp = "1";
24req.phone.mlppDomainId = "1";
25req.phone.dndRingSetting = "5";
26
27StandardResponse res = AXLAPIServiceSingleton.getInstance().addPhone(req);
The request:
 2<?xml version="1.0" encoding="UTF-8"?>
 3<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
 4   <soap:Body>
 5      <addPhone xmlns="http://www.cisco.com/AXL/API/8.5">
 6         <phone xmlns="">
 7            <name>CSF4SIG</name>
 8            <description>CH3 CSF AAA-10241</description>
 9            <protocolSide>User</protocolSide>
10            <callingSearchSpaceName>Internal-CH3</callingSearchSpaceName>
11            <devicePoolName>CH3</devicePoolName>
12            <commonDeviceConfigName>CH3-Device Config</commonDeviceConfigName>
13            <commonPhoneConfigName>CH3-Common Phone Profile</commonPhoneConfigName>
14            <locationName>CH3</locationName>
15            <mediaResourceListName xsi:nil="true" />
16            <networkHoldMohAudioSourceId>1</networkHoldMohAudioSourceId>
17            <userHoldMohAudioSourceId>1</userHoldMohAudioSourceId>
18            <automatedAlternateRoutingCssName xsi:nil="true" />
19            <aarNeighborhoodName xsi:nil="true" />
20            <loadInformation xsi:nil="true" />
21            <versionStamp>1</versionStamp>
22            <mlppDomainId>1</mlppDomainId>
23            <useTrustedRelayPoint>Default</useTrustedRelayPoint>
24            <securityProfileName>Cisco Unified Client Services Framework - Standard SIP Non-Secure</securityProfileName>
25            <sipProfileName>JABBER SIP Profile</sipProfileName>
26            <cgpnTransformationCssName xsi:nil="true" />
27            <geoLocationName xsi:nil="true" />
28            <geoLocationFilterName xsi:nil="true" />
29            <phoneTemplateName>Standard Client Services Framework</phoneTemplateName>
30            <primaryPhoneName xsi:nil="true" />
31            <userlocale />
32            <networkLocale />
33            <idleTimeout>5</idleTimeout>
34            <softkeyTemplateName xsi:nil="true" />
35            <defaultProfileName xsi:nil="true" />
36            <builtInBridgeStatus>Default</builtInBridgeStatus>
37            <ownerUserName>SIG</ownerUserName>
38            <packetCaptureMode>None</packetCaptureMode>
39            <subscribeCallingSearchSpaceName>Internal-CH3</subscribeCallingSearchSpaceName>
40            <rerouteCallingSearchSpaceName xsi:nil="true" />
41            <certificateOperation>No Pending Operation</certificateOperation>
42            <deviceMobilityMode>Default</deviceMobilityMode>
43            <dndRingSetting>5</dndRingSetting>
44            <mobilityUserIdName xsi:nil="true" />
45            <mobileSmartClientProfileName xsi:nil="true" />
46            <dialRulesName xsi:nil="true" />
47            <featureControlPolicy xsi:nil="true" />
48         </phone>
49      </addPhone>
50   </soap:Body>
51</soap:Envelope>
The response:
 1<?xml version="1.0" encoding="UTF-8"?>
 2<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
 3   <soapenv:Body>
 4      <soapenv:Fault>
 5         <faultcode>soapenv:Client</faultcode>
 6         <faultstring>A character to numeric conversion process failed</faultstring>
 7         <detail>
 8            <axlError>
 9               <axlcode>-1213</axlcode>
10               <axlmessage>A character to numeric conversion process failed</axlmessage>
11               <request>addPhone</request>
12            </axlError>
13         </detail>
14      </soapenv:Fault>
15   </soapenv:Body>
16</soapenv:Envelope>
I understand well that the error is that I am trying to store a value with non numerical character into a numeric DB field as described here (http://www-01.ibm.com/support/docview.wss?uid=swg21432403).
However I am running out of idea on how to correct.
Any help would be highly appreciated.
Subject: RE: New Message from Salim Guerid in AXL Developer - Administration XML Que
Replied by: Dennis Heim on 01-11-2013 02:11:22 AM
Have you tried creating it by hand (via CCM Admin gui), and then doing a getPhone xml request and comparing that to what you are sending?
Dennis Heim | Solution Architect (Collaboration)
World Wide Technology, Inc. | 314-212-1814
PS Engineering:  Innovate & Ignite.
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Friday, November 01, 2013 1:31 AM
To: [email protected]
Subject: New Message from Salim Guerid in AXL Developer - Administration XML Questions: AddPhone: A character to numeric conversion process failed
Salim Guerid has created a new message in the forum "Administration XML Questions": -------------------------------------------------------------- Hi all,
2AddPhoneReq req = new AddPhoneReq();
3req.phone = new XPhone();
4req.phone.name = "CSF4" + userID;
5req.phone.description = site + " CSF " + userID + "-" + extension;
6req.phone.devicePoolName = new XFkType() { Value = siteDevicePool };
7req.phone.commonDeviceConfigName = new XFkType() { Value = site + "-Device Config" };
8req.phone.phoneTemplateName = new XFkType() { Value = PhoneButtonTemplate };
9req.phone.commonPhoneConfigName = new XFkType() { Value = site + "-Common Phone Profile" };
10req.phone.callingSearchSpaceName = new XFkType() { Value = stdLineCSS[0] + "-" + site };
11req.phone.locationName = new XFkType() { Value = site };
12req.phone.sipProfileName = new XFkType() { Value = stdCSFSIPProfile };
13req.phone.securityProfileName = new XFkType() { Value = DeviceSecurityProfile };
14req.phone.subscribeCallingSearchSpaceName = new XFkType() { Value = stdLineCSS[0] + "-" + site };
15req.phone.ownerUserName = new XFkType() { Value = userID };
16
17// Values added to try to address the issue
18req.phone.packetCaptureDuration = "0";
19req.phone.networkHoldMohAudioSourceId = "1";
20req.phone.userlocale = "";
21req.phone.networkLocale = "";
22req.phone.userHoldMohAudioSourceId = "1";
23req.phone.idleTimeout = "5";
24req.phone.versionStamp = "1";
25req.phone.mlppDomainId = "1";
26req.phone.dndRingSetting = "5";
27
28StandardResponse res = AXLAPIServiceSingleton.getInstance().addPhone(req);
The request:
4   <soap:Body>
6         <phone xmlns="">
31            <userlocale />
37            <ownerUserName>AAA</ownerUserName>
48         </phone>
49      </addPhone>
50   </soap:Body>
51</soap:Envelope>
The response:
3<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
4   <soapenv:Body>
5      <soapenv:Fault>
6         <faultcode>soapenv:Client</faultcode>
7         <faultstring>A character to numeric conversion process failed</faultstring>
8         <detail>
9            <axlError>
10               <axlcode>-1213</axlcode>
11               <axlmessage>A character to numeric conversion process failed</axlmessage>
12               <request>addPhone</request>
13            </axlError>
14         </detail>
15      </soapenv:Fault>
16   </soapenv:Body>
17</soapenv:Envelope>
To respond to this post, please click the following link: http://developer.cisco.com/web/axl-developer/forums/-/message_boards/view_message/20888328 or simply reply to this email.
Replied by: Salim Guerid on 03-11-2013 01:30:31 AM
Here is the getPhone:
  3   <soapenv:Body>
  4      <ns:getPhoneResponse xmlns:ns="http://www.cisco.com/AXL/API/8.5">
  5         <return>
  6            <phone uuid="{518B7F58-3FDF-6AA1-5805-CD7689C35260}">
  8               <description>CH3 CSF SIG - 10241</description>
  9               <product>Cisco Unified Client Services Framework</product>
 10               <model>Cisco Unified Client Services Framework</model>
 11               <class>Phone</class>
 12               <protocol>SIP</protocol>
 13               <protocolSide>User</protocolSide>
 14               <callingSearchSpaceName uuid="{EF109E49-4A93-A715-FC2A-7289028A5A17}">Internal-CH3</callingSearchSpaceName>
 15               <devicePoolName uuid="{0F0744C4-D8F1-0956-31C9-7ADEC4AB908B}">CH3</devicePoolName>
 16               <commonDeviceConfigName uuid="{D4867809-E67E-48D5-496D-BE31BCECDAF1}">CH3-Device Config</commonDeviceConfigName>
 17               <commonPhoneConfigName uuid="{76BE71E3-09AF-0198-A376-DF389E8767AB}">RTCP Common Phone Profile</commonPhoneConfigName>
 18               <networkLocation>Use System Default</networkLocation>
 19               <locationName uuid="{6C8460FB-FD64-B611-6A9B-2A327C22EB28}">CH3</locationName>
 20               <mediaResourceListName />
 21               <networkHoldMohAudioSourceId />
 22               <userHoldMohAudioSourceId />
 23               <automatedAlternateRoutingCssName />
 24               <aarNeighborhoodName />
 25               <loadInformation special="false" />
 26               <vendorConfig>
 27                  <videoCapability>1</videoCapability>
 28                  <desktopClient>
 29                     <ciscoSupportField />
 30                  </desktopClient>
 31               </vendorConfig>
 32               <versionStamp>{1383458960-7D0DB871-8FD5-44F8-9D42-3D2A4F9D2FE2}</versionStamp>
 33               <traceFlag>false</traceFlag>
 34               <mlppDomainId />
 35               <mlppIndicationStatus>Off</mlppIndicationStatus>
 36               <preemption>Disabled</preemption>
 37               <useTrustedRelayPoint>Default</useTrustedRelayPoint>
 38               <retryVideoCallAsAudio>true</retryVideoCallAsAudio>
 39               <securityProfileName uuid="{C6085E14-A32C-4C5E-A3D1-8DAF60D81594}">Cisco Unified Client Services Framework - Standard SIP Non-Secure</securityProfileName>
 40               <sipProfileName uuid="{95C28F72-AFA3-5F1A-BA09-6204C9DD5121}">Jabber SIP Profile</sipProfileName>
 41               <cgpnTransformationCssName />
 42               <useDevicePoolCgpnTransformCss>true</useDevicePoolCgpnTransformCss>
 43               <geoLocationName />
 44               <geoLocationFilterName />
 45               <sendGeoLocation>false</sendGeoLocation>
 46               <lines />
 47               <numberOfButtons>1</numberOfButtons>
 48               <phoneTemplateName uuid="{8E1A10FA-A52C-4435-A4EC-540D266C8C37}">Standard Client Services Framework</phoneTemplateName>
 49               <speeddials />
 50               <busyLampFields />
 51               <primaryPhoneName />
 52               <ringSettingIdleBlfAudibleAlert>Default</ringSettingIdleBlfAudibleAlert>
 53               <ringSettingBusyBlfAudibleAlert>Default</ringSettingBusyBlfAudibleAlert>
 54               <blfDirectedCallParks />
 55               <addOnModules />
 56               <userlocale />
 57               <networkLocale />
 58               <idleTimeout />
 59               <authenticationUrl />
 60               <directoryUrl />
 61               <idleUrl />
 62               <informationUrl />
 63               <messagesUrl />
 64               <proxyServerUrl />
 65               <servicesUrl />
 66               <services />
 67               <softkeyTemplateName />
 68               <defaultProfileName />
 69               <enableExtensionMobility>false</enableExtensionMobility>
 70               <currentProfileName />
 71               <loginTime />
 72               <loginDuration />
 73               <currentConfig>
 74                  <userHoldMohAudioSourceId />
 75                  <phoneTemplateName uuid="{8E1A10FA-A52C-4435-A4EC-540D266C8C37}">Standard Client Services Framework</phoneTemplateName>
 76                  <mlppDomainId />
 77                  <mlppIndicationStatus>Off</mlppIndicationStatus>
 78                  <preemption>Disabled</preemption>
 79                  <softkeyTemplateName />
 80                  <ignorePresentationIndicators>false</ignorePresentationIndicators>
 81                  <singleButtonBarge>Off</singleButtonBarge>
 82                  <joinAcrossLines>Off</joinAcrossLines>
 83                  <callInfoPrivacyStatus>Default</callInfoPrivacyStatus>
 84                  <dndStatus />
 85                  <dndRingSetting />
 86                  <dndOption>Ringer Off</dndOption>
 87                  <alwaysUsePrimeLine>Default</alwaysUsePrimeLine>
 88                  <alwaysUsePrimeLineForVoiceMessage>Default</alwaysUsePrimeLineForVoiceMessage>
 89                  <emccCallingSearchSpaceName xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" uuid="" />
 90                  <deviceName />
 91                  <model />
 92                  <product />
 93                  <deviceProtocol />
 94                  <class />
 95                  <addressMode />
 96                  <allowAutoConfig />
 97                  <remoteSrstOption />
 98                  <remoteSrstIp />
 99                  <remoteSrstPort />
100                  <remoteSipSrstIp />
101                  <remoteSipSrstPort />
102                  <geolocationInfo />
103               </currentConfig>
104               <singleButtonBarge>Off</singleButtonBarge>
105               <joinAcrossLines>Off</joinAcrossLines>
106               <builtInBridgeStatus>Off</builtInBridgeStatus>
107               <callInfoPrivacyStatus>Default</callInfoPrivacyStatus>
108               <hlogStatus>On</hlogStatus>
109               <ownerUserName uuid="2d43fc2e-8cea-4e5e-6d71-09781d33c4a5">SIG</ownerUserName>
110               <ignorePresentationIndicators>false</ignorePresentationIndicators>
111               <packetCaptureMode>None</packetCaptureMode>
112               <packetCaptureDuration>0</packetCaptureDuration>
113               <subscribeCallingSearchSpaceName />
114               <rerouteCallingSearchSpaceName />
115               <allowCtiControlFlag>true</allowCtiControlFlag>
116               <presenceGroupName uuid="{AD243D17-98B4-4118-8FEB-5FF2E1B781AC}">Standard Presence group</presenceGroupName>
117               <unattendedPort>false</unattendedPort>
118               <requireDtmfReception>false</requireDtmfReception>
119               <rfc2833Disabled>false</rfc2833Disabled>
120               <certificateOperation>No Pending Operation</certificateOperation>
121               <certificateStatus>None</certificateStatus>
122               <upgradeFinishTime />
123               <deviceMobilityMode>Default</deviceMobilityMode>
124               <remoteDevice>false</remoteDevice>
125               <dndOption>Ringer Off</dndOption>
126               <dndRingSetting />
127               <dndStatus>false</dndStatus>
128               <isActive>true</isActive>
129               <isDualMode>false</isDualMode>
130               <mobilityUserIdName />
131               <phoneSuite>Default</phoneSuite>
132               <phoneServiceDisplay>Default</phoneServiceDisplay>
133               <isProtected>false</isProtected>
134               <mobileSmartClientProfileName />
135               <mtpRequired>false</mtpRequired>
136               <mtpPreferedCodec>711ulaw</mtpPreferedCodec>
137               <dialRulesName />
138               <sshUserId />
139               <digestUser />
140               <outboundCallRollover>No Rollover</outboundCallRollover>
141               <hotlineDevice>false</hotlineDevice>
142               <secureInformationUrl />
143               <secureDirectoryUrl />
144               <secureMessageUrl />
145               <secureServicesUrl />
146               <secureAuthenticationUrl />
147               <secureIdleUrl />
148               <alwaysUsePrimeLine>Default</alwaysUsePrimeLine>
149               <alwaysUsePrimeLineForVoiceMessage>Default</alwaysUsePrimeLineForVoiceMessage>
150               <featureControlPolicy />
151               <deviceTrustMode>Not Trusted</deviceTrustMode>
152            </phone>
153         </return>
154      </ns:getPhoneResponse>
155   </soapenv:Body>
156</soapenv:Envelope>
Replied by: Dennis Heim on 03-11-2013 01:00:40 AM
A few things:
·         Leave MLPP blank. It is showing 1
·         sipProfileName is showing as JABBER SIP Profile and on the other Jabber SIP Profile (I can only assume caps matter)
·         useDevicePoolCgpnTransformCss is missing (Check the axl schema if that is required.
If none of that fixes it, I would turn up the axl logs temp. to detailed and then review those. Sometimes the detailed axl logs give more details as to what is going on.
16
27
The request:
4   <soap:Body>
6         <phone xmlns="">
31            <userlocale />
48         </phone>
49      </addPhone>
50   </soap:Body>
51</soap:Envelope>
The response:
4   <soapenv:Body>
5      <soapenv:Fault>
8         <detail>
9            <axlError>
13            </axlError>
14         </detail>
15      </soapenv:Fault>
16   </soapenv:Body>
Replied by: Salim Guerid on 03-11-2013 02:22:48 AM
Ok, checked the API an added the min occurrence=1 fields in my request:
1req.phone.@class = "Phone";
2req.phone.product = "Cisco Unified Client Services Framework";
3req.phone.protocol = "SIP";
4req.phone.packetCaptureMode = "None";
5req.phone.protocolSide = "User";
6req.phone.useTrustedRelayPoint = "Default";
7req.phone.certificateOperation = "No Pending Operation";
8req.phone.deviceMobilityMode = "Default";
The CSF is still not created but the error changed now to -1.
The request:
 2<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
 3   <soap:Body>
 4      <addPhone xmlns="http://www.cisco.com/AXL/API/8.5">
 5         <phone xmlns="">
 6            <name>CSF4SIG</name>
 7            <description>CH3 CSF SIG-10241</description>
 8            <product>Cisco Unified Client Services Framework</product>
 9            <class>Phone</class>
10            <protocol>SIP</protocol>
11            <protocolSide>User</protocolSide>
12            <callingSearchSpaceName>Internal-CH3</callingSearchSpaceName>
13            <devicePoolName>CH3</devicePoolName>
14            <commonDeviceConfigName>CH3-Device Config</commonDeviceConfigName>
15            <commonPhoneConfigName>CH3-Common Phone Profile</commonPhoneConfigName>
16            <locationName>CH3</locationName>
17            <mediaResourceListName xsi:nil="true" />
18            <networkHoldMohAudioSourceId xsi:nil="true" />
19            <userHoldMohAudioSourceId xsi:nil="true" />
20            <automatedAlternateRoutingCssName xsi:nil="true" />
21            <aarNeighborhoodName xsi:nil="true" />
22            <loadInformation xsi:nil="true" />
23            <versionStamp xsi:nil="true" />
24            <mlppDomainId xsi:nil="true" />
25            <useTrustedRelayPoint>Default</useTrustedRelayPoint>
26            <securityProfileName>Cisco Unified Client Services Framework - Standard SIP Non-Secure</securityProfileName>
27            <sipProfileName>JABBER SIP Profile</sipProfileName>
28            <cgpnTransformationCssName xsi:nil="true" />
29            <geoLocationName xsi:nil="true" />
30            <geoLocationFilterName xsi:nil="true" />
31            <phoneTemplateName>Standard Client Services Framework</phoneTemplateName>
32            <primaryPhoneName xsi:nil="true" />
33            <userlocale xsi:nil="true" />
34            <networkLocale xsi:nil="true" />
35            <idleTimeout xsi:nil="true" />
36            <softkeyTemplateName xsi:nil="true" />
37            <defaultProfileName xsi:nil="true" />
38            <builtInBridgeStatus>Default</builtInBridgeStatus>
39            <ownerUserName>SIG</ownerUserName>
40            <packetCaptureMode>None</packetCaptureMode>
41            <subscribeCallingSearchSpaceName>Internal-CH3</subscribeCallingSearchSpaceName>
42            <rerouteCallingSearchSpaceName xsi:nil="true" />
43            <certificateOperation>No Pending Operation</certificateOperation>
44            <deviceMobilityMode>Default</deviceMobilityMode>
45            <dndRingSetting xsi:nil="true" />
46            <mobilityUserIdName xsi:nil="true" />
47            <mobileSmartClientProfileName xsi:nil="true" />
48            <dialRulesName xsi:nil="true" />
49            <featureControlPolicy xsi:nil="true" />
50         </phone>
51      </addPhone>
52   </soap:Body>
53</soap:Envelope>
The response:
 3   <soapenv:Body>
 4      <soapenv:Fault>
 5         <faultcode>soapenv:Server</faultcode>
 6         <faultstring />
 7         <detail>
 8            <axlError>
 9               <axlcode>-1</axlcode>
10               <axlmessage />
12            </axlError>
13         </detail>
14      </soapenv:Fault>
15   </soapenv:Body>
Any idea?
Replied by: Salim Guerid on 03-11-2013 02:30:44 AM
Hi Dennis,
 - Leave MLPP blank. It is showing 1
--> I set that value for testing but removed it in my last test as you can see in the request.
--> I spoted that one an renamed the profile into the CCM.
--> I have tested with or without setting this value but it does not change.
Do you know if:
I need to precise the sequence value? I am not sure what it is and what's the impact?
I need to mention the a line? Apparently it is not ncessary.
I will check how to turn up the axl logs, I am not sure exactly where it is located.
Replied by: Salim Guerid on 03-11-2013 08:43:29 AM
Well, I have set the AXL log to Debug and here is the result
 12013-11-03 15:19:00,017 DEBUG [http-8443-7] axlapiservice.Handler - insert into Device ( fkCallingSearchspace_restrict,tkDeviceProtocol,tkPacketCaptureMode,SpecialLoadInformation,tkStatus_MLPPIndicationStatus,tkStatus_DeviceMobilityMode,tkProtocolSide,fkDevicePool,fkPhoneTemplate,fkCallingSearchSpace,fkEndUser,fkCallingSearchspace_reroute,tkStatus_BuiltInBridge,fkSIPProfile,isprotected,tkPreemption,fkDialRules,Description,fkAARNeighborhood,fkCommonDeviceConfig,ikDevice_defaultProfile,fkcallingsearchspace_cgpntransform,fkMediaResourceList,tkCertificateOperation,fkLocation,Name,tkClass,fkCommonPhoneConfig,tkdndoption,pkid,fkCallingSearchSpace_AAR,fkFeatureControlPolicy,fkSecurityProfile,tkStatus_UseTrustedRelayPoint,tkProduct ) values ( 'ef109e49-4a93-a715-fc2a-7289028a5a17','11','0',null,'0','2','1','0f0744c4-d8f1-0956-31c9-7adec4ab908b','8e1a10fa-a52c-4435-a4ec-540d266c8c37','ef109e49-4a93-a715-fc2a-7289028a5a17','2d43fc2e-8cea-4e5e-6d71-09781d33c4a5',null,'2','95c28f72-afa3-5f1a-ba09-6204c9dd5121','f','0',null,'CH3 CSF SIG-10241',null,'d4867809-e67e-48d5-496d-be31bcecdaf1',null,'ef109e49-4a93-a715-fc2a-7289028a5a17',null,'1','6c8460fb-fd64-b611-6a9b-2a327c22eb28','CSF4SIG','1','577a1e46-aba7-5e2a-f7ab-4999c65c78ba','0','da3cf717-cfca-a52c-7209-2499b4c6c401',null,null,'c6085e14-a32c-4c5e-a3d1-8daf60d81594','2','390' )
 22013-11-03 15:19:00,170 DEBUG [http-8443-7] axlapiservice.Handler - getPkid Query is :select pkid from CallingSearchSpace where my_lower(name ) =my_lower('Internal-CH3' )
 32013-11-03 15:19:00,174 ERROR [http-8443-7] axlapiservice.AXLAPIServiceSkeleton - com.cisco.www.axlapiservice.AXLAPIServiceSkeleton@37fe9e
 4java.lang.NullPointerException
 5        at com.cisco.www.axlapiservice.AddPhoneHandler.doAdd(AddPhoneHandler.java:931)
 6        at com.cisco.www.axlapiservice.AXLAPIServiceSkeleton.addPhone(AXLAPIServiceSkeleton.java:13345)
 7        at com.cisco.www.axlapiservice.AXLAPIServiceMessageReceiverInOut.invokeBusinessLogic(AXLAPIServiceMessageReceiverInOut.java:7446)
 8        at org.apache.axis2.receivers.AbstractInOutMessageReceiver.invokeBusinessLogic(AbstractInOutMessageReceiver.java:40)
 9        at org.apache.axis2.receivers.AbstractMessageReceiver.receive(AbstractMessageReceiver.java:100)
10        at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:176)
11at org.apache.axis2.transport.http.HTTPTransportUtils.processHTTPPostRequest(HTTPTransportUtils.java:275)
12        at org.apache.axis2.transport.http.AxisServlet.doPost(AxisServlet.java:131)
13        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
14        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
15        at sun.reflect.GeneratedMethodAccessor2444.invoke(Unknown Source)
16        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
17        at java.lang.reflect.Method.invoke(Method.java:597)
18        at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:269)
19        at java.security.AccessController.doPrivileged(Native Method)
20        at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
21        at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:301)
22        at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
23        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:283)
24        at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:56)
25        at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:189)
26        at java.security.AccessController.doPrivileged(Native Method)
27        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:185)
28        at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
29        at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
30        at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
31at org.apache.catalina.core.ApplicationDispatcher.access$000(ApplicationDispatcher.java:65)
32        at org.apache.catalina.core.ApplicationDispatcher$PrivilegedForward.run(ApplicationDispatcher.java:80)
33        at java.security.AccessController.doPrivileged(Native Method)
34        at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:294)
35        at com.cisco.www.servletRouters.AXLAlpha.doPost(Unknown Source)
36        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
37        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
38        at sun.reflect.GeneratedMethodAccessor2444.invoke(Unknown Source)
39        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
40        at java.lang.reflect.Method.invoke(Method.java:597)
41        at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:269)
42        at java.security.AccessController.doPrivileged(Native Method)
43        at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
44        at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:301)
45        at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
46        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:283)
47        at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:56)
48        at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:189)
49        at java.security.AccessController.doPrivileged(Native Method)
50        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:185)
51...
522013-11-03 15:19:00,178 DEBUG [http-8443-7] axlapiservice.AXLCallFlow - In AXL CAll Flow2013-11-03 15:19:00,179 DEBUG [http-8443-7] axlapiservice.AXLCallFlow - In AXL CAll Flow errorCodeStringnull
What looks super anoying to me is that if I run manually the query found in the log, It works pretty well:
1admin:run sql ccm insert into Device ( fkCallingSearchspace_restrict,tkDeviceProtocol,tkPacketCaptureMode,SpecialLoadInformation,tkStatus_MLPPIndicationStatus,tkStatus_DeviceMobilityMode,tkProtocolSide,fkDevicePool,fkPhoneTemplate,fkCallingSearchSpace,fkEndUser,fkCallingSearchspace_reroute,tkStatus_BuiltInBridge,fkSIPProfile,isprotected,tkPreemption,fkDialRules,Description,fkAARNeighborhood,fkCommonDeviceConfig,ikDevice_defaultProfile,fkcallingsearchspace_cgpntransform,fkMediaResourceList,tkCertificateOperation,fkLocation,Name,tkClass,fkCommonPhoneConfig,tkdndoption,pkid,fkCallingSearchSpace_AAR,fkFeatureControlPolicy,fkSecurityProfile,tkStatus_UseTrustedRelayPoint,tkProduct ) values ( 'ef109e49-4a93-a715-fc2a-7289028a5a17','11','0',null,'0','2','1','0f0744c4-d8f1-0956-31c9-7adec4ab908b','8e1a10fa-a52c-4435-a4ec-540d266c8c37','ef109e49-4a93-a715-fc2a-7289028a5a17','2d43fc2e-8cea-4e5e-6d71-09781d33c4a5',null,'2','95c28f72-afa3-5f1a-ba09-6204c9dd5121','f','0',null,'CH3 CSF SIG-10241',null,'d4867809-e67e-48d5-496d-be31bcecdaf1',null,'ef109e49-4a93-a715-fc2a-7289028a5a17',null,'1','6c8460fb-fd64-b611-6a9b-2a327c22eb28','CSF4SIG','1','577a1e46-aba7-5e2a-f7ab-4999c65c78ba','0','da3cf717-cfca-a52c-7209-2499b4c6c401',null,null,'c6085e14-a32c-4c5e-a3d1-8daf60d81594','2','390' ) Rows: 1
Before it is beeing said, I run CCM version 8.6.2.20000-2 and is not able to upgrade in a reasonable timeframe.
Replied by: Dennis Heim on 03-11-2013 10:01:40 AM
It almost sounds like some type of AXL Bug.
Sent: Sunday, November 03, 2013 9:44 AM
Subject: New Message from Salim Guerid in AXL Developer - Administration XML Questions: RE: AddPhone: A character to numeric conversion process failed
Salim Guerid has created a new message in the forum "Administration XML Questions": -------------------------------------------------------------- Well, I have set the AXL log to Debug and here is the result [@theme_images_path@/emoticons/sad.gif]
32013-11-03 15:19:00,174 ERROR [http-8443-7] axlapiservice.AXLAPIServiceSkeleton - com.cisco.www.axlapiservice.AXLAPIServiceSkeleton@37fe9e<mailto:com.cisco.www.axlapiservice.AXLAPIServiceSkeleton@37fe9e>
51...
What looks super anoying for me is that if I run manually the query found in the log, It works pretty wel:
To respond to this post, please click the following link: http://developer.cisco.com/web/axl-developer/forums/-/message_boards/view_message/20932528 or simply reply to this email.
Replied by: Salim Guerid on 03-11-2013 03:02:17 PM
Replied by: Salim Guerid on 25-11-2013 12:40:01 AM
Cisco TAC was useful
Such nul pointer exception could be caused by not mentionning the mobilityUserIdName:
1req.phone.mobilityUserIdName = new XFkType() { Value=userID};
Problem solved.
Next one here...
