cdnadmin
Community Member
This document was generated from CDN thread
Created by: Cindy Brozyno on 27-12-2011 12:51:04 PM
I am writing a time clock app; this part of the code checks last transaction for type (in/out) so they don't try to punch in w/o punching out, or vice versa.
Working with the clock out routine.
Successful IF there is a previous record in the database; however, if this is their first transaction, I am unable to resolve.
Please review code below and see if you can identify a solution.  Any help is GREATLY appreciated.
Cindy
//Is the person is trying to punch out w/o punching in?
    var input=Request.QueryString("input"); //comes from the Phone Input (previous page)
    var Conn = Server.CreateObject("ADODB.Connection");
    var RS = Server.CreateObject("ADODB.Recordset");
    var sql2;
    var str;
    Conn.Open("Provider=SQLNCLI10;Data Source=xxx;Persist Security Info=False;Initial Catalog=IPTimeClock;Uid=xxx;Pwd=xxx;");
    sql2=("SELECT Type FROM dbo.tblTransactions WHERE TransID=(SELECT MAX(TransID)from dbo.tblTransactions WHERE UserID="+input+")");
    RS.CursorType=2;
    RS.Open(sql2, Conn);
    str=RS("Type");
    if (RS.EOF == true and RS.BOF == true)
        Clockout(input);
    }else
    RS.MoveFirst();
    if (str="O")
    Response.Write("<CiscoIPPhoneText>\r\n");
    Response.Write("<Title>IP Time Clock</Title>");
    Response.Write("<Text>You are currently clocked OUT.\r\n  Please Clock In First.</Text>\r\n");
    Response.Write("</CiscoIPPhoneText>\r\n");
    else{Clockout(input);}
    //RS.close;
    //Conn.close;
    //RS=null;
    //Conn=null;
Subject: RE: ADO Select query problem
Replied by: Florian Kroessbacher on 28-12-2011 04:43:46 AM
Hy Cindy,
What about to count this here
and if the count is zero then there was no transaction
cheers Floh
Replied by: Cindy Brozyno on 01-02-2012 07:19:38 AM
Thank you, Florian, for your advice.  The only way I was able to resolve was by changing the end of my query to UserID = "+input+" or 0 - and adding a default record with 0 as the ID.   I do appreciate the assistance.
