Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Lewis Mackey on 15-04-2009 03:42:02 PM I am using Call Studio 6.0 to debug an application. In the application error log, I see a "error with admin service startup" message. The application is looking for the logger class com.cisco.cvp.vxml.datafeed.DatafeedLogger. Where can I find this class and which folder does it go in? I have attached the errorlog file to help clarify my request. Thanks.
Subject: Re: New Message from Lewis Mackey in Customer Voice Portal (CVP) - General Replied by: Janine Graves on 15-04-2009 09:02:39 PM The dataFeedLogger is used to interface between the Vxml Server and the Reporting Server. If you do not have the Reporting Server then you can go into the Studio app's Project/Properties/General Settings window. In the Loggers box at the bottom, highlight the DataFeedLogger and press Remove. That should alleviate the problem.
However, if you leave that logger, you should be able to still run your program, but the system will complain and display an error message each time you run the updateApp or deployApp script.
Janine
Cisco Developer Community Forums wrote: > Lewis Mackey has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > I am using Call Studio 6.0 to debug an application. In the application > error log, I see a "error with admin service startup" message. The > application is looking for the logger class > com.cisco.cvp.vxml.datafeed.DatafeedLogger. Where can I find this > class and which folder does it go in? I have attached the errorlog > file  to help clarify my request. Thanks. > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1291514> > > or simply reply to this email.
