cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mert Guray on 14-11-2008 03:02:05 PM
We are trying to start usin ASR of Nuance in our applications. We already set up the Nuance Server. It seems running with English. We will try to run it in Turkish as well. however i am vonfused about the grammer. I think i should point the grammar from the Call Studio applcation. But i couldn't find where i should do that. Grammar files are located on Nuance Server. Right?
Should i also put it somewhere like VXML Server or else?
Thanks in advance.
Subject: Re: ASR implmentation
Replied by: Janine Graves on 14-11-2008 03:29:41 PM
Use the form element and fill in the setting named voice grammar or dtmf grammar.
Most people store their grammars on their media server. In that case use the URL to request it. If its on the ASR server in a file then use the file:backslash backslash Format to point to it. In both cases the ASR server retrieves the grammar.
Replied by: Mert Guray on 14-11-2008 03:38:11 PM
Thanks for info.
Does it mean that we have to use form element to have ASR in our system. I would expect to be having this facility in the user input kind of elements like menu or digits elements.
Replied by: Janine Graves on 14-11-2008 08:24:41 PM
By the way, with the grammars, the standard 'builtin' grammars (digits,
date, time, number, currency, boolean, phone) come with the ASR. The
Studio elements of the same name uses these grammars.
Or to mix/match different builtin grammars, use the Form element and
configure the setting named VoiceGrammar to builtin:grammar/date (for
example) and configure the setting DTMF Grammar to builtin:dtmf/date
The format to explicitly use the builtin grammars is:
'builtin:grammar/name' for the voice grammar
'builtin:dtmf/name' for the dtmf grammar
Replied by: Janine Graves on 14-11-2008 08:25:41 PM
Yes, you can configure the menu element and the system will build a
grammar for you. You can use the Digits, Date, Number, etc elements to
invoke the standard builtin grammars. But, if you want to create your
own grammars and invoke them, then you must use the Form element.
