This document was generated from CDN thread
Created by: Paulo Silva on 29-09-2011 09:58:35 AM
Using an ExecuteSQLQuery call with the following query:
"SELECT d.name, eu.telephoneNumber FROM Device d INNER JOIN EndUser eu ON eu.pkid = d.fkenduser WHERE UPPER(eu.userid) = '" + userName.ToUpper() + "'"
In addition to the device name and telephone number, i would like to know if the device is a hard phone or a IP Communicator.
Does anybody know how to do that?
Thanks in advance,
Paulo Silva
Subject: RE: Assistance using ExecuteSQLQuery
Replied by: Steven Lass on 29-09-2011 10:24:25 AM
Join with the typeproduct table using device.tkproduct.
-steve
Replied by: Keith Lunn on 29-09-2011 10:27:50 AM
The "device" table field you are interested in is "device.tkProduct".
Also device.tkclass = '1' will select only devices that are class = phones. (I include this as first in the SQL WHERE clause)
Example code snippet showing values of device.tkproduct that you can sleect in a SQL:
var supportedPhones = []; //typeProduct.enum values
supportedPhones[supportedPhones.length] = '30023'; // 7902
supportedPhones[supportedPhones.length] = '35'; // 7960
supportedPhones[supportedPhones.length] = '36'; // 7940
supportedPhones[supportedPhones.length] = '30018'; // 7970
supportedPhones[supportedPhones.length] = '30044'; // 7965
supportedPhones[supportedPhones.length] = '30002'; // 7920
supportedPhones[supportedPhones.length] = '20003'; // 7905
supportedPhones[supportedPhones.length] = '30022'; // 7912
supportedPhones[supportedPhones.length] = '30044'; // 7961
supportedPhones[supportedPhones.length] = '303'; // 7962
supportedPhones[supportedPhones.length] = '32'; // 7935 - conference station
supportedPhones[supportedPhones.length] = '30050'; // 7936 - conference station
supportedPhones[supportedPhones.length] = '330'; // 7937 - newer conference station
supportedPhones[supportedPhones.length] = '30041'; // IP Communicator (CIPC)
supportedPhones[supportedPhones.length] = '25'; // CTI Ports
All the various enum values are found in the typeproduct table as device.tkproduct is an enum field that is a key linked to table "typeproduct".
