cdnadmin
Community Member
This document was generated from CDN thread
Created by: Sanjay Gulati on 10-08-2010 07:30:54 PM
Hey Guys,
I am trying to run audio files over HTTP path but for some reason Audio element does not like the HTTP Path.
There are no access issues to audio file i.e. i can run the audio files from the browser.
Audio element runs fine if i give the default path but gives error when i try to run it over Http.
Is there some special settings that i need to do ? Any help will be appreciated.
Sanjay
Subject: Re: New Message from Sanjay Gulati in Customer Voice Portal (CVP) - CVP - A
Replied by: Janine Graves on 10-08-2010 07:48:36 PM
There's nothing special you need to do, other than ensure the gateway
has access to the URL that you specify.
Can you ping the IP address of your http string from the voicexml gateway?
Open a web browser  and copy/paste the same URL that you have in Studio
(do NOT use localhost in the URL, use the IP address or hostname).
The web browser should try to retrieve the audio file and play it. If it
can't then perhaps there's an error in your URL string.
What do you mean 'it runs fine if I give the default path' versus using
'http'?
Janine
On 8/10/2010 3:30 PM, Cisco Developer Community Forums wrote:
> Sanjay Gulati has created a new message in the forum "CVP - All Versions":
> Hey Guys,
> Â
> Â
> Â
> appreciated.
> Â
> Thanks
> Sanjay
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2424608>
> or simply reply to this email.
Janine Graves
781-990-1040
Subject: RE: Audio file over http Path
Replied by: Hemal Mehta on 10-08-2010 07:52:47 PM
Can you post the exact error the logs are showing? Make sure that you do not have the default path box checked on and you are trying to use in the path.
Replied by: Sanjay Gulati on 10-08-2010 08:35:34 PM
There is no Error log.
The call just get disconnect with no error. But if i check the sessions then i can see hanging sessions.
Replied by: Sanjay Gulati on 10-08-2010 09:31:25 PM
Thanks for your response.
What do you mean 'it runs fine if I give the default path' versus using  'http'?
I meant if i check the checkbox "use the default audio path" and use local path on VXML server like "/CVP/Audio/**.wav" than it runs with no problem but if i uncheck the default path checkbox and put http path then it does not seems to be working.
I have verified the gateway can ping the http path audio files but still its not working.
Sanjay
Replied by: Janine Graves on 10-08-2010 09:59:36 PM
What's the URL that you enter into Studio?
> Â
> using  'http'?
> Â
> Â
> Â
> Thanks
> Sanjay
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2425909>
Janine Graves
781-990-1040
Replied by: Janine Graves on 10-08-2010 10:00:36 PM
can you turn on gateway debug logging on the gateway:
'term mon'
'debug http client error'
and see what it says.
> Â
> using  'http'?
> Â
> Â
> Â
> Thanks
> Sanjay
Janine Graves
781-990-1040
