cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 03-06-2003 06:33:46 PM
Are audio files required to be in the Tomcat/webapps/audium/audio directory? Everytime I try to re-direct an audio to be played from, for example, c:\msgs\ directory, I get an error that the page can not be found.
Tracey
Subject: RE: audio file path
Replied by: null on 03-06-2003 09:33:45 PM
Hi Tracey,
Audio files are NOT required to be in the Tomcat/webapps/audium/audio directory. The only requirement is that the audio files are accessible via http. Therefore, the audio files can be served from any web or application server of your choosing. This can be located on the same machine or application server as the Audium server or on another remote machine. Since audio file references are put directly into the vxml "src" attribute, local paths will not work (unless your voice browser supports loading/accessing audio directly from the vxml platform).
For example, you could put all your audio in
Tomcat/webapps/ROOT/myaudio
and then you should be able to refer to the audio files in the Audium builder audio item configuration as "/myaudio/file.wav".
Note: the Audium application supports relative paths if a full url is none is specified.
I hope this answers your question.
Joe
