cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 24-04-2007 08:57:19 PM
I'm having issues w/ the timeout of a record element and am wondering if anyone has run into this before and can offer some advice.
[b:2ea8c657fc]The Environment:[/b:2ea8c657fc]
CVP 3.1 w/ Audium 3.6.
[b:2ea8c657fc]The problem:[/b:2ea8c657fc]
If the caller leaves a long message (> 15sec approx) they get cut off w/ a busy signal. If they leave a shorter message, things work totally fine.
There is no error log and the activity log makes it look like the caller hung up.
[b:2ea8c657fc]Things I've Tried:[/b:2ea8c657fc]
I have modified the 'max recording time' setting a bunch w/in the app and it doesn't make any difference.
I have checked the settings w/in the CVP combo box and there doesn't seem to be a setting related to recording time
Could it be a setting on the vxml gatway or something?
Thanx,
ryan
Subject: RE: Audium Record Element Issues.....
Replied by: Cheng-Dar Yang on 25-04-2007 09:02:27 PM
Hi Ryan,
The generated VXML adheres to VXML specification. The record elements makes use of "maxtime" attribute to control the maximum allowed recording time.
Your description of the recording getting cut off with busy signal indicates that the VXML browser (which handle the actual voice interaction), is causing the cut off. Unless your application was configured to generate the busy signal, this is most likely caused by the browser.
When the gateway receives the VXML page instructing it to begin recording. It keeps the active recording in memory (or temp file) until recording is completed. The gateway then submits the recording back to VXML server. It's conceivable that the gateway runs out of memory or mis-configured so that it cuts off the recording when it exceeds certain duration.
As for the VXML gateway settings, I suggest that you contact Cisco TAC and open a case to troubleshoot this issue.
Cheng
